checking out 87t2 what to look 4??
Old Sep 5, 2002 | 10:00 AM
osiris7's Avatar
hi, everyone, im gonna check out a t2 this weekend and i wanted to know if there's anything in particular for the t2 model to look for..I had 7 NA's in the past but this will be the 1st t2...thanx
Old Sep 5, 2002 | 11:22 AM
jacobcartmill's Avatar
just dont care.
make sure it idles. and when you romp the gas, watch for smoke to come out of the exhaust when you come back down to a stop. mine did this when i bought it (i didnt notice it) then i got home with it and i ended up replacing my turbo (blown turbine)
Old Sep 5, 2002 | 12:00 PM
vaughnc's Avatar
knowledge junkie
osiris7,
Hey your going to love the difference between the TII and NAs. Nothing like having power in all gears
Are you looking at a Series IV or V TII?
As usual, compression test by the local mazda dealership. After that make sure it boosts fine, handles good, no rust, no frame damage, all A arms & suspension pieces are there, check for rust in the spare tire compartment, etc..
expect the usual stuff - sticky sunroof, wipers work on medium only, etc..
How many miles are on the car and engine?
Old Sep 5, 2002 | 12:04 PM
eViLRotor's Avatar
Brother of the Rotary
Check for excessive shaft play on the compressor...
Old Sep 5, 2002 | 01:02 PM
osiris7's Avatar
thanks everyone, its gonna be a series 4 t2 with a 91 block..So basically when i go for a test drive i should accelerate hard and look for smoke after i close the throttle??
Old Sep 5, 2002 | 03:30 PM
just dont care.
yeah, if you get smoke when you get back to idle, it probably has a blown turbine, which pretty much means new turbo. what does rust in the spare tire compartment mean?
Old Sep 5, 2002 | 05:15 PM
vaughnc's Avatar
knowledge junkie
It's a quick way to tell if the car was ever in a minor fender bender. Chances are if the drain plug in the rear is missing or loose or you see "waivyness" in the compartment, it was hit.
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
JoesFC
Oct 5, 2015 08:10 AM
Tem120
Sep 7, 2015 09:53 AM
rotor_veux
Sep 3, 2015 07:10 PM
