chattering in reverse when car is cold
Old Sep 4, 2002 | 11:40 PM
777rx777's Avatar
Everytime I start my car (when its cold, and i go to back out of a parking spot, etc. it chatters bad in reverse. Its a stock clutch. What could cause this? The clutch was replaced about 1 year ago the clutch is still strong (it breaks the tires loose and I have 18s) what could the problem be?
thanks...
chris
Old Sep 5, 2002 | 12:13 AM
Cetchup's Avatar
The Cursed FD
Does it only do this in reverse? Or other gears aswell? When my car is cold and I take it for a drive I always have a problem with the transition from 1st to 2nd, so i just go from 1st to nuetral then to 2nd gear. After it's all warmed up everything is smooth. Maybe try that?
Old Sep 5, 2002 | 12:17 AM
777rx777's Avatar
Yeah mine does that too. Sometimes it grinds into second when its cold. I have to do the same thing as you. Hey, but at least we don't have any of those "grandma automatic 7's."
Old Sep 5, 2002 | 03:40 AM
FD Racer's Avatar
sold the FD...kept the FB
mine does it in 1st and in reverse. It is the worst when the car is cold. I blame a posible combination of things: posible warped clutch disc, worn motor mounts, and my light (9.5lb) flywheel.
Old Sep 6, 2002 | 12:12 AM
7-sins's Avatar
thats not paint....
This happens to me if I dont start mixing the clutch at about 2k. I am thinking it's a motor mount, we will see once I get a Torque bar if it helps.
NoMorePoison
11
Aug 18, 2015 11:18 AM
ncds_fc
Aug 15, 2015 10:06 AM
Wolf_
Aug 11, 2015 04:23 PM
