Fitting an External fuel pump?
Old Sep 4, 2002 | 05:20 PM
How do i go about fitting an External fuel pump to my 1990 T2?
Does anyone have a write up on this subject?
Thanks.
Old Sep 4, 2002 | 05:50 PM
I wish I was driving!
Re: Fitting an External fuel pump?
Thanks.
I run an aeromotive external 1200 hp pump. What do you want to know? What pump are you lloking at? Fuel cell, or stock tank?
Old Sep 4, 2002 | 06:07 PM
Ok i want to keep the std tank but run a realy big External.
I would like to know how i adapt my std Intank to an External?
Also i have ben told to change my injector set up to a Parallel type rather than a Std inline?
I am just trying to get the best fuel system i can afford.
Thanks.....Chris
Old Sep 4, 2002 | 06:12 PM
I run parallel, somewhat modifed.
Remove the stock pump, and block off the line. Weld a sump in place, with the tank removed, upside down and filled with water, and mount the pump to the frame using rubber isolators.
Old Sep 4, 2002 | 06:29 PM
I dont supose you have a Pic do you? what happens to the Fuel level sender?
Old Sep 4, 2002 | 06:37 PM
Leave it attached. Just disconnect the wiring to the stock pump, and remove the pump. Replace the entire unit, and block off the output hoses.
No pics, sorry.
Old Sep 4, 2002 | 07:07 PM
Sorry i'm a bit confused, I use the stock Pump frame/Sender remove the Pump and block off the outlet pipe (so the sender still works) then weld a sump into the bottom of the tank (making sure i dont blow myself up lol) the bit i dont get is how i get a good take off for the feed to the pump at the bottom of the Tank?
Do i just Weld a pipe to the side of the sump? and what sort of size would it need to be?
Thanks for the Help......Chris
Old Sep 4, 2002 | 07:34 PM
Wow i've just had a look at some of the Aeromotive pumps.
Do you recomend them? What Hp will they safely run?
Thanks.......Chris
befarrer
Microtech
Aug 22, 2015 05:52 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
