I just Ran engine Codes, Got a "30" ???
Old Sep 3, 2002 | 09:56 PM
RangerJoeEOD's Avatar
Question I just Ran engine Codes, Got a "30" ???
I got teh how too sheet from 1300cc.com and read the code 30 but his list dose not list a 30. It was 3 long flashes and repeat. Dose any one have a complete list of codes? BTW i have an 89 GTUs Thnaks
Old Sep 3, 2002 | 10:25 PM
deadRX7Conv's Avatar
Opinions are like........
Try 03 if it isn't 30
Just scroll down to the bottom!
http://www.1300cc.com/howto/how2/codes.html
http://home.rmci.net/panther/89_91ecu.htm
Old Sep 3, 2002 | 10:31 PM
Scott 89t2's Avatar
SOLD THE RX-7!
scroll down The FSM has it split up like that.... I just copied it.
split air solenoid valve
Old Sep 4, 2002 | 05:18 PM
Thank you all alot, i guess i did not print the hole thing. has anyone ever replaced one?
Old Sep 4, 2002 | 05:25 PM
is the "Solenoid valve-split air bypass" (as in http://home.rmci.net/panther/89_91ecu.htm) the same as "split air Solenoid valve" (in the FSM)? I hope so
Old Sep 4, 2002 | 05:27 PM
never mind i got it I am a dumb ***
Old Sep 4, 2002 | 05:38 PM
spazzytroy's Avatar
20b Tinkerer
hey guys, how bout a way to check codes for us peeps w/ S4's. You can get thoes code checkers at Autozone for like $30 (hopefully you get more than you pay for ), would these even work, or is there another way?
Old Sep 4, 2002 | 10:37 PM
J-Rat's Avatar
Alcohol Fueled!
DO NOT BUY A CODE CHECKER FOR THE S4!!!!! Use the L.E.D. setup that you use to check your TPS. I dont have the link, but the tester that you build will cost you about 2 bucks.
Rat
Anyone got the link?
Old Sep 4, 2002 | 10:57 PM
can anyone tell em where you find the split air solenoid valve, i got it FSM page but can find the thing on the car please help, track date in 2 days Thanks again
C. Ludwig
Jan 30, 2019 06:31 AM
The Shaolin
Sep 14, 2015 07:50 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
