water level sensor
Old Sep 3, 2002 | 08:09 PM
Albey RX-7's Avatar
water level sensor
my water level sensor (oem piece of plastic) craked at the threads which causes coolant to leak. Is there some aftermarket replacement for it, that is better? Or do I have to stay with an oem replacement from the dealer?
Old Sep 4, 2002 | 03:30 AM
dingleberry's Avatar
Hey bro the AEM one is fine, thats kind of unual for it to break so AEM is fine....
dingle..
Old Sep 4, 2002 | 10:36 AM
TobiasRX's Avatar
Mine cracked to. I just milled out an aluminium plate and put an o-ring between. Works great!!
If i polish it will look better to
Old Sep 4, 2002 | 01:32 PM
sszablya's Avatar
Model photographer!
Maybe that's why I get the low coolant buzzer every month or so?? The car just sits in the garage an awful lot. At about 1 month intervals, I fire it up and 30 seconds later... buzzzzzzzz! Then I gotta fill'er up with 50/50... I should check that darndamn thing.
Old Aug 5, 2012 | 10:49 AM
corsaconvertible's Avatar
Trio of Black and Gold
Water level sensor
I have the same problem.
Can you explain in more detail, and perhaps add a photo.
I'm going to try and just replace it with a bolt until I get a proper repair. I'll post the size if I find something.
Thanks, Tony
Old Aug 5, 2012 | 02:31 PM
water level sensor
Mine cracked to. I just milled out an aluminium plate and put an o-ring between. Works great!! If i polish it will look better to
I'm going to try and just replace it with a bolt until I get a proper repair. I'll post the size if I find something. Thanks, Tony
The coolant leak at the water level sensor is for now stopped with a M12x1.25 bolt. If I cannot repair the sensor today, I'll order a new one tomorrow. Tony (aka: corsaconvertible)
Old Aug 6, 2012 | 08:47 AM
Fritz Flynn's Avatar
All out Track Freak!
I have several sensors in good shape. PM me if you need one
Old Aug 7, 2012 | 08:30 AM
CloudPump's Avatar
Thanks, Tony
Ten year old thread. You might not get a reply.
-Geoff
rotary_rx7fc
20
Sep 19, 2015 02:41 PM
msilvia
15
Sep 11, 2015 12:13 PM
mulcryant
Sep 9, 2015 05:24 PM
