Sputtering
Old Jul 23, 2001 | 02:16 PM
TNIGHT's Avatar
Sputtering
I have a 93 base. upon purchase it ran fairly well with exception of no 2nd turbo action .Anyway I go in replace and tie the vac. lines get everything back together. builds up speed as long as I don't stab the gas pedal which is when it bucks and sputters.
Any help is appreciated!!!!!!!!!!!1
Old Jul 23, 2001 | 09:01 PM
nrolfes1's Avatar
I had this problem, it was a weak engine ground. I reinforced the ground by putting a big ol fat wire from the engine to the chassis and it fixed the problem immediately.
Old Jul 24, 2001 | 12:11 AM
Bucrx7's Avatar
Check your plugs and your wires. If you sputters when you gun it then you'll most likely need new plugs.
Tony S.
Old Aug 5, 2001 | 10:23 PM
TNIGHT's Avatar
Plugs and wires are new ground is good I tied the vacuum lines the hole silicon replacement deal and I have been in twice and nothing appears pinched but I can hear a surge when I release the throttle not the same as a bov release
PinkRacer
43
Oct 1, 2015 09:13 AM
sherff
Sep 12, 2015 12:22 PM
RotaryBobby
Sep 10, 2015 01:33 PM
rx7shirley
Sep 2, 2015 02:11 PM
PhillyFC
Aug 21, 2015 06:36 PM
