View Poll Results: Did it work? Unplugging the O2 sensor
Yes
33.33%
Nope
66.67%
Voters: 6. You may not vote on this poll
Anyone with hesitation Try this!!!
Old Sep 3, 2002 | 04:18 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Worked for me. I have the O2 sensor switched... But I just leave it off....
Old Sep 3, 2002 | 04:24 PM
SPOautos's Avatar
Hey, where did my $$$ go?
How is that going to affect close loop though??? Closed loop is where the computer looks at the O2 sensor to determine if its rich or lean and makes changes accordingly.....thats really all the O2 is used for.
It might be that the PFS PMC doesnt use closed loop.....but if that were the case I dont see why unhooking the O2 sensor would change anything.
I have a PFC and I dont use my O2 sensor at all. You can turn the O2 sensor off on the PFC and it will read from the fuel map at all times instead of running closed loop.
STEPHEN
Old Sep 3, 2002 | 04:37 PM
rotary-tt's Avatar
2 babies - no back seats
That just masks the problem if you use the stock cpu by running the motor richer. It does not get to the root of the problem...
Old Sep 3, 2002 | 04:58 PM
poss's Avatar
Slower Traffic Keep Right
since no one has been able to FIND the root of the problem for every car, it is the next best thing.
Old Sep 3, 2002 | 05:04 PM
93 R1's Avatar
Re: Anyone with hesitation Try this!!!
Originally posted by Dont_Be_A_Rikki
Hello all here is something for you guys out there that still have hesitation. I am almost sure this will clear it up 99% of at least. So try it. I have done it on 2 cars now both using PFS PMC system. It works awsome so give it a shot and let me know if it works for you guys.
So:
1.)Unplug the O2 sensor from the connection point just behind the UIM turbo side.
2.)Take her for a spin.
Let me know.
-Rikki
Yeah I was the ginuea pig.
Worked great for me so far.
Old Sep 3, 2002 | 05:24 PM
93 R1's Avatar
Old Sep 3, 2002 | 07:18 PM
rotary-tt's Avatar
The actual problem is probably one of the items listed under Hesitation\Surging in Section F of the shop manual.
Old Sep 3, 2002 | 07:19 PM
Blade7's Avatar
hey ryan,
I don't have a pfc but do have the m2's stage 3 rechipped ecu. will that work?
thanks
donnie
Old Sep 3, 2002 | 08:48 PM
SPOautos's Avatar
It could also be that your O2 is bad. When they start to go they read rich that means your ecu is going to pull back with the fuel.
Rikki if you had hesitation probs you prob just needed to add fuel to some cells, thats all unpluging the O2 is doing more than likely. Get Peter to go over your light throttle fuel, its prob just too lean. Unhooking the O2 is probably making it super rich.
STEPHEN
Old Sep 3, 2002 | 08:52 PM
From: Minnesota, now in FL and I dont think I'm goin back
so you just pull it out? I have a PFC could I still do it? what about the hole that it leaves do u plug that?
Old Sep 3, 2002 | 08:55 PM
93 R1's Avatar
Peter told me:
The hesitation/bucking(NOT 3K) at light throttle is caused due to a lean misfire. The factory(Mazda) maps are programmed this way for emissions purposes, the PMC "amplifies" these maps and makes it more noticable.
By unplugging the o2 sensor the ecu does not see the light throttle lean condition and try to compensate for it, thus causing the hestiation/bucking.
Its just a band-aid for a bigger problem.
Old Sep 3, 2002 | 09:56 PM
silver93's Avatar
yeah, the O2 trick is an old one which, if it does work for a bit, will not solve the problem (usually) and it will come back. trying to play with the fuel maps around 3K is again a wasted effort.
Assuming you have already cleaned, and added bigger, better and more grounds, the best thing to do is unplug the PMC from the car, and drive it around for a day with just the stock ECU. Then plug the PMC back in -
of course, if you have improper fuel pressure, dirty or dripping injectors, or bad grounds, you should take care of that too.
Old Sep 4, 2002 | 10:47 AM
93 R1's Avatar
I've had mine unhooked for about 1800 miles. No CE light yet and no hesitation.
We are not referring to the 3K hesitation in this post. Unhooking the o2 sensor probably will not have any effect the 3k hesitation at all.
Old Sep 4, 2002 | 10:57 AM
This is for the hesitation at light throttle right? Is there any other cures to this
Old Sep 4, 2002 | 12:10 PM
SPOautos's Avatar
But it will create a overly rich condition. If you have the PMC why not just richen up the fields that are lean???? By unpluging the O2 your going to make it overly rich.
My stock computer never had this problem....I wonder if the maps were changed sometime between 93 and 95 to smooth things out.
Rikki, if you pull the pmc out and just drive around with the ecu only do you have these problems??? It might just be tuning that needs to be cleaned up with the PMC
STEPHEN
rgordon1979
40
Mar 15, 2022 12:04 PM
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
lnlreaper
Sep 27, 2015 09:59 AM
