Gauge Clusters
Old Sep 3, 2002 | 12:07 AM
ShaunB's Avatar
Question Gauge Clusters
Are all Gauge Clusters swapable, im getting a 87 turbo 2 but not gonna turbocharge it, gonna supercharge it, so could i use a 89-91 NA gauge cluster. or would i have to use a 86-88 gauge cluster.
Old Sep 3, 2002 | 12:11 AM
blackdragonsocal's Avatar
Good question....I've got a '87 Turbo II but I like the round 89-91 gauges and since the stock boost gauge is useless I wouldn't mind getting rid of it.
Old Sep 3, 2002 | 12:30 AM
rx_7_driver's Avatar
i think there is a diif between the s4 and s5 cluster
just do a search something should come up
Old Sep 3, 2002 | 03:44 AM
adamlewis's Avatar
Back from teh deadly!
89-91 NA Gagues will have an 8k redline on the tach while T2's redline at 7k.
86-88 NA's had 7k redlines though.
Old Sep 3, 2002 | 09:28 AM
DaleClark's Avatar
RX-7 Bad Ass
You can swap in the '89-91 cluster into an '86-88 car, but you'll have to do a little work with the wiring harness. A little sit-down with both shop manuals and you should be good to go.
Dale
Old Sep 3, 2002 | 11:37 PM
Has anyone done this I like the round look better also
Old Sep 4, 2002 | 12:36 AM
silverrotor's Avatar
If you want to be creative, do as I am currently doing. Have your Black front plate, the one In the Instrument Cluster, sent out to be plastic chromed. Any place that works with vacuum metalizing machines will do this. Infact, the same could be said about my MAZDA RX-7 badges. It should turn out mint!
Old Sep 4, 2002 | 01:47 AM
Icemark's Avatar
Its been covered here many times, and even what pins need to be moved.
I would suggest the search thing for anyone considering swaping the gauges between series.
as to the T2 to NA swap it should be plug in as long as you keep the same series.
