Car not Starting. Help.
Old Aug 29, 2002 | 05:11 PM
Beep777's Avatar
My 88 N/A 5 speed intermittenly doesnt start. For a couple days it is OK and a couple days it wont start, When not starting, you turn the key and just hear the circuit opening relay under the dash click and nothing else.
I Have: Swapped starters, bypassed the interlock switch, and bypassed the starter cut relay. Nothing.
Is this connected to the alarm system? If so, wouldnt bypassing the starter cut relay solve this?
This sux not knowing if the car will start or not. Help!
Brian
Old Aug 29, 2002 | 05:38 PM
rxguru's Avatar
completely wankelfied
Did you test the battery? Sounds stupid I know but sometimes the obvious is over looked.
Old Aug 29, 2002 | 08:22 PM
Beep777's Avatar
Not the battery. Everything lights up, and the click click from the circuit opening relay. If it was a battery connection problem, there would be no noise from the relay.
Old Aug 30, 2002 | 02:04 PM
SSearch's Avatar
Have you checked the battery cables, good ground, and battery connections? If it is a loose ground you will be able to run the lights and everything fine, but when you put a high amperage load on the system it will crap out.
Old Aug 30, 2002 | 02:11 PM
Aaron Cake's Avatar
Engine, Not Motor
Battery cables. Replace them.
Could also be the actual key switch in the steering column.
Jose A.
19
Aug 27, 2015 11:41 PM
Leeroy_25
Aug 17, 2015 12:53 PM
andyvideopro
Aug 11, 2015 09:16 PM
