HELP !!!! Problem with Microtech on '89 on Turbo II
Old Aug 29, 2002 | 02:53 PM
Peter Ball's Avatar
I have my car sitting 300k from home waiting to have a Microtech MT 8 fitted. The guy doing this work - Pip Gardner from WGT Autos here in the U.K. has hit a problem in that the 1989 Turbo II operates the oil injection from the OEM ECU. There doesn't seem to be any provision on the Microtech to drive the oil injection.
Has anyone else fitted this ECU to a 1989 0n car (from what I know, the answer to this has to be yes) and, if so, how have they overcome this ?
Many thanks in advance for any help that you can give.
Peter
Old Aug 29, 2002 | 03:00 PM
SonicRaT's Avatar
Super Raterhater
You could simply remove the 89 Electronic metering oil pump and oil injection and run premix instead, should be able to get block off plates from K2RD I believe. This is one option you can try.
Old Aug 29, 2002 | 03:02 PM
zyounker's Avatar
root
Or you can buy this
http://www.rotaryaviation.com/oil_in...p_adaptors.htm
it will convert it to a RPM based pump.. you will also need a tank to hold 2 cycle oil.. and check it regularly..
-Zach
Old Aug 29, 2002 | 03:04 PM
KNONFS's Avatar
B O R I C U A
Or use the mechanical system found in the 86-88 FC.
Old Aug 29, 2002 | 03:08 PM
SonicRaT's Avatar
Super Raterhater
Note that the above requires changing front covers, as well as rigging up the linkage (or getting a series 4 TB, but that only has the single sensor TPS...) that the mechanical pump used.
Old Aug 29, 2002 | 03:17 PM
zyounker's Avatar
root
The one i posted does not require changeing all of that. i would either use it or premix.. Those are your best options.
-Zach
Old Aug 29, 2002 | 03:26 PM
SonicRaT's Avatar
Super Raterhater
Yeah, thanks for that link zyounker, never saw that before and damn I'm gonna pick it up!
Old Aug 29, 2002 | 03:28 PM
banzaitoyota's Avatar
What Subscription?
Or trash the microtech and get the new haltech EK11 ?
Has provision to run the 89 OMP.
I would ditch the OMP and run PRemix mself.. OOPS I have!
Old Aug 29, 2002 | 03:35 PM
zyounker's Avatar
root
No problem
If you want to run synthetic this is a way to do it without worry too.. (same with premix)
Premix is probably safest. But as long as you have a good OMP this should be safe. I would recomend makeing sure your omp is good though. i recently lost an engine because my OMP got plugged
-Zach
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
