streetportign teh NA will the stock ECU ahndle it?
Old Aug 29, 2002 | 01:25 AM
Kahren's Avatar
i am not a girl
after the streetport do i need to give it more fuel. or will teh stock ecu/injectors/fuel pump handle this. i have a full rb exhasut, DP,MP, catback. pineapple 6 port sleeves and a cold air induction.
Old Aug 29, 2002 | 01:33 AM
Liquid Anarchy's Avatar
We come with the Hardcore
Best bet, get some TII 550cc injectors, and an Apex S-AFC. The End.
BTW, hod do you have a DP on an N/A?
Old Aug 29, 2002 | 01:36 AM
I thought I'd clearify.
TII 550cc SECONDAIRY Injectors. Either get an A/F and EGT gague to tune it, or head to your local dyno, and tune to the torque curve.
Old Aug 29, 2002 | 01:57 AM
hypntyz7's Avatar
You dont need any of that stuff for just a SP and exhaust and intake.
I built my buddies GXL with a heavy SP, intake and full race exhaust, adn ran it off the stock ecu and injectors. IT ran STRONG too. The NA is tunes rich enough from the factory that you ahve a fair amount of slack. Dyno reports have shown that a stock NA makes more power by LEANING it out in teh midrange, not richening it up. The stock EFI can handle just about whatever you throw at it, short of a BP or something.
IMO that stuff on an NA is a waste of money, unless youre buying the SAFC to tune DOWN the STOCK injectors...
Now, a t2 is totally different.
Old Aug 29, 2002 | 02:03 AM
breesej's Avatar
Amish Gangsta
I have a street port and didn't need 550's or S-AFC
my injectors are clean and the car pulls nice. all FC's are tuned a little on the fat side for safety, adding a little more air via street port won't hurt your motor.
I actually noticed a slow down with 550's in the secondaries. The car was not as responsive above 4000 RPM as it was with the 460's.
My advise is to have the motor ported, break it in and get it dyno'ed as is, with stock injectors and a wide band. I'm sure it will say you are running a little on the rich side. From there then you decide, but I wouldn't just go out and buy **** cause you heard it here, from somebody who doesn't know your specific application.
Old Aug 29, 2002 | 02:53 AM
peejay's Avatar
Old [Sch|F]ool
why would the stock ECU run lean?
Old Aug 29, 2002 | 01:45 PM
Kahren's Avatar
i am not a girl
thats what i was planning on doing, goign to dyno after break in with the fuel being stock, and then seing if i have to get an AFC or injectors. the "DP" is the precat replacement pipe. thanx
Old Aug 29, 2002 | 02:24 PM
Aaron Cake's Avatar
Engine, Not Motor
The stock NA fuel system is good for 250 HP....Are you going to be making more than that? Doubt it.
Invest in an S-AFC to help tune things in.
Old Aug 29, 2002 | 05:18 PM
pp13bnos's Avatar
Pineapple Racer
Yeah...don't touch the injectors, and buy a s-afc. CJ
C. Ludwig
Jan 30, 2019 06:31 AM
incubuseva
14
Sep 3, 2015 12:37 PM
