help me out guys....
Old Aug 29, 2002 | 12:20 AM
nitroracer's Avatar
Dub'N
ok guys here we go.
my car smokes like crazy when i start it up, when its cold.
i know i saw other links and read them all. i was told it could be my oil metering pump so tomorrow im gunna go to the junkyard and get one out of a car. or could u tell me what else it could be that makes my car smoke like that.
if i understand right the oil metering pump has a vavle that opens up to let oil into the chambers . and my chamber isent closing all the way. so when i turn my car off it causes oil to seep into the chamber....right?
also i have perfect compression.
i was just wondering what u guys would think if it is or not is my oil metering pump?
plz dont put this link off
Old Aug 29, 2002 | 12:25 AM
blackdragonsocal's Avatar
If the smoke is white it could be your that your coolant seals are gone, letting coolant into the combustion chamber. What year is your car? If it's a S4 then it's probably not your OMP and actually if it's a S5 it's probably not your OMP either cause when those fail they don't allow any oil into the motor.
Old Aug 29, 2002 | 12:28 AM
Forgot to add this but, your OMP uses 4 injectors (kind of like fuel injectors) to get oil into your housings. Oil can't just flow in there, it's got to be pumped and "injected".
Old Aug 29, 2002 | 12:30 AM
nitroracer's Avatar
Dub'N
ya thats what i thought t did...aso my car is a s5
Old Aug 29, 2002 | 12:35 AM
Then your OMP is electrical and if it does fail then no lubricating oil will get into your housings. I don't think the OMP is your problem....are you losing coolant?
Old Aug 29, 2002 | 04:44 PM
nitroracer's Avatar
Dub'N
no im not losing coolent..but i hate the smoke. and i want to fix it.
Old Aug 29, 2002 | 04:57 PM
SonicRaT's Avatar
Super Raterhater
What color is the smoke?
Old Aug 29, 2002 | 04:58 PM
jimmyv13's Avatar
Round&Round not Up&Down
Could be your oil control rings.
How often do you add oil?
Old Aug 29, 2002 | 05:12 PM
turboren's Avatar
somebody beat me to the punch...
I had the same thing happen to a 90 GXL that I had. Compression was fine, and it only had like 120k on it, but it smoked blue a lot. I didn't drive it a lot, so it didn't really seem worth it to me to replace the rings, which, of course, require a complete teardown and rebuild.
Ren
NAN777
Sep 19, 2006 01:39 AM
zie001
Dec 9, 2005 07:42 AM
spoolage
Sep 21, 2003 02:22 AM
Poweraxel
Mar 12, 2003 02:25 AM
spoolage
Nov 2, 2002 03:37 PM
