Bad compression
Old Aug 28, 2002 | 11:58 PM
drinkyourmilk's Avatar
Hamburglar
Bad compression
Hi everyone, I'm new here..
I'm considering buying an rx-7 as my first car (heh.. I want one bad ) The guy selling it said that the car runs but has bad compression on the second lobe/rotor .. I'm curious if this is fixable + how much it will cost to do.. Also could you tell me what I would need to buy and how to do it.. It's an '86 NA..
Thanks alot for any help
Old Aug 29, 2002 | 12:01 AM
Felix Wankel's Avatar
Super Newbie
Engine rebuild. Figure 1-2 thousand dollars.
Unless you find a junkyard engine that runs good. My brother bought an 86-88 NA engine for 300 bucks that appears to be a rebuild.
Old Aug 29, 2002 | 12:06 AM
Hamburglar
Is that my only option?? (Thanks for the quick response)
Old Aug 29, 2002 | 12:37 AM
blackdragonsocal's Avatar
A rebuild is the only way to get the compression back up....but how does the car run? Steady idle? Good power? It may still have some life left in it.
Old Aug 29, 2002 | 12:56 AM
Juan's Avatar
Im a tall midget.
A rebuild, junkyard engine, or a used engine (not from a junkyard) are basically your options. Rebuilds start at $1000. Ive seen some junkyards that sell their engines for $150-300 dollars. Used engines that people sell online/offline run for about $500 I think. Good luck with the car if you decide to buy it.
Old Aug 29, 2002 | 12:59 AM
Hamburglar
Not sure how it runs.. I'm buying it from an auction (I know.. bad idea..) The guy is in MD.. I'm in PA.. So I can't test drive it..
He said he only drove it to move it across a lot..
Don't know how comfortable I would feel driving it home 200 miles..
Can you put a newer engine in it.. Like a '91?
Old Aug 29, 2002 | 08:39 AM
That really doesn't sound good. These cars will run for a while even after an apex seal is blown....they won't run good (i.e. terrible idle and no power). It sounds like this guy might be trying to unload the car. Figure 2g's to put a new motor in (yes you can put in a newer engine, but search the forums on how to do that) and then try to start talking the guy down. Without you being able to see the compression numbers and here how the car runs in person then I wouldn't recommend this car unless you get it for dirt cheap.
Old Aug 29, 2002 | 10:42 AM
Hamburglar
Currently the bid is at $100..
Old Aug 29, 2002 | 12:16 PM
Well hell, if you're looking for a project then you couldn't go wrong at that price!
Old Aug 29, 2002 | 02:17 PM
Hamburglar
Last question.. Where in the northeast region can I get it rebuilt? Preferably in Pennsylvania..
Old Aug 29, 2002 | 02:35 PM
banzaitoyota's Avatar
What Subscription?
Shipping isn't that bad. You can get one from Malloy MAzda , MAZDA REMAN for around 1900. They are in Northern VA?. Pineapple Racing does HIGH quality rebuilds with an excellant warrenty. For a "quickie" [less money/less good stuff] try Hyptynz7 {Kevin Landers}.
Shipping for my last motor SC to OR and OR to SC was 306 total.
But remeber, in the end you get what you paid for.
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
