can exhaust leak cause bad idle?
Old Aug 27, 2002 | 09:21 PM
jacobcartmill's Avatar
just dont care.
can an exhaust leak cause a rough idle?
Old Aug 27, 2002 | 09:47 PM
rx_7_driver's Avatar
u and i both want to know this one
Old Aug 27, 2002 | 09:51 PM
theflatlander's Avatar
Dual Wielding DieGrinders
same here
Old Aug 27, 2002 | 09:57 PM
seventhgear's Avatar
boost on the way(GTU II)
same here !
Old Aug 27, 2002 | 09:59 PM
lol we all have exhaust leaks and all have bad idles on our cars
anyone else?
shawn
90 N/A Vert
Old Aug 27, 2002 | 10:07 PM
just dont care.
haha, yeah. if a leak can actually cause a bad idle, i'll spend the time to fix the leak
Old Aug 27, 2002 | 10:17 PM
lol
ok would anyone with a good idle would like to go loosen the exhaust bolts and tell us if there idle changed? (i prefer someone with an n/a s5)lol
Old Aug 27, 2002 | 10:19 PM
momar's Avatar
I have an S4 and had a small exhuast leak where the precats connected to eachother. The pipe was rusted enough that it made a small hole, but anyways my idle was fine back then.
Old Aug 27, 2002 | 10:29 PM
damn anyone know with an s5? i am hopeing its just an leak and the idle is rough cause of lack of back pressure r something related to that
Old Aug 27, 2002 | 10:34 PM
shouldnt be because i had one of my mufflers off for a while and no messed up idle then .... big loss of power and back press. though
Old Aug 27, 2002 | 10:39 PM
i'm talking about a leak before the main cat, mabe even the pre cats......... it might even be the manifold that is leaking on mine
Old Aug 27, 2002 | 10:45 PM
manifold leak maybe but right now im wondering ur question too i have a leak at the main cat seeing thatz the only cat i have
Old Aug 27, 2002 | 10:46 PM
J-Rat's Avatar
Alcohol Fueled!
I had a leak after the manifold, at the first pre-cat. Idle was good.
Old Aug 27, 2002 | 10:57 PM
j-rat s4 r s5? r it dosen't make a diff. which series it is?
Old Aug 27, 2002 | 11:30 PM
Ryde _Or_Die's Avatar
I wouldn't think the series would make any difference.
Old Aug 28, 2002 | 12:16 AM
just dont care.
well does anyone have the answer to our question or what?
Old Aug 28, 2002 | 12:24 AM
SonicRaT's Avatar
Super Raterhater
I have a series 4 with about 16 holes in it, starting at the main cat all the way back, idles rock solid at 750
Old Aug 28, 2002 | 12:37 AM
ACTION RT's Avatar
G35 FTW
lol sonic,
i have a leak right somewhere by my turbo or downpipe. can't diagnose it. Start the car and it has that really annoying noise, crappy exhaust leak. Gets really loud at 2-4 and then i can't hear it anymore. Ever since it developed it feels like my car is loosing power once boost hits. like not enough kick in the pants there anymore. getting the full exhaust replaced with 3inch mandrel bent single from the engine to a reactive muffler
Old Aug 28, 2002 | 03:05 AM
J-Rat's Avatar
Alcohol Fueled!
S4
Old Aug 28, 2002 | 03:14 AM
The Ace's Avatar
Greek Power
NO
Exhaust leak can not affect idle.
Intake leak can. Bad TPS can. Clogged filter and/or AFM can. etc etc......
I had MASSIVE exhaust leaks (exhaust manifold AND turbo were cracked like a ****) and the idle was perfect. TID cracked, or filter was slightly clogged, or the TPS out of specs, and the idle would bounce a bit (not much though....)
Old Aug 28, 2002 | 03:21 AM
David Hu$tlerhoff's Avatar
everything after th turbo is restriction, so get the **** rid of those cats, pre-cats, mufflers etc
Kyo
Apr 13, 2019 09:24 AM
86glxNA
Aug 22, 2015 08:54 PM
