Anyone installed Indiglo gauges from Ebay?
Old Aug 27, 2002 | 06:08 PM
DCmina's Avatar
Hi, I am almost done installing them but now I need to connect the electrical stuff.
Can anyone tell me where the red and black wires go?
I'm gonna try and make a diagram:
.._____......._____
./_/_/_/___/_/_/_/
/_/_/_/_/._/_/_/_/
Thanks!
Old Aug 27, 2002 | 06:28 PM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
red go to a positive, and black go to a negative.
Old Aug 27, 2002 | 06:30 PM
I hooked mine up to the radio remote positive, so when I turn off the oignition in my car, the indiglos shut off by themselves
Old Aug 27, 2002 | 06:31 PM
DCmina's Avatar
Thanks but I still got no idea where that is.
Could you tell me where in my diagram to put the red and black wires?
thanks
Old Aug 27, 2002 | 06:34 PM
if you have a test light, hook it up to a good ground and star testing your wires, anything that lights up with the ignition on should work.
Old Aug 27, 2002 | 06:37 PM
DCmina's Avatar
Thanks, I'll try...
but if you could tell me just where to put them
Old Aug 27, 2002 | 06:45 PM
Icemark's Avatar
are the red and black wires the only wires coming from the indiglow gauge faces or controller??
Old Aug 27, 2002 | 06:53 PM
TurboSmoke's Avatar
Getting Boosted
i have a set of reverse indiglo ones i have to figure out
Old Aug 27, 2002 | 06:55 PM
DCmina's Avatar
yes
thanks
Old Aug 27, 2002 | 06:57 PM
TurboSmoke's Avatar
Getting Boosted
what kind of gaudges are they
Old Aug 27, 2002 | 07:14 PM
Icemark's Avatar
Then if you want them to come on when the ignition is on, hook the red one to the Black/yellow at the back of the cluster or Black/white at the ignition switch.
If you want them to come on with the lights, hook the red wire to the red/black wire found at the radio, or light switch, or CPU in the drivers kick panel, or the glove box light,
The black wire should go to one of the solid black (or black with dots) wires coming from the cluster.
Old Aug 27, 2002 | 07:17 PM
TurboSmoke's Avatar
Getting Boosted
on the instructions on my car it said do not attach to fact dimmers could blow them up. which is the wire for the dimmers so i dont attach them
Old Aug 27, 2002 | 07:22 PM
Icemark's Avatar
The factory dimmer wires are Red/green. That should not be used for a indiglow type gauge cover!!!
Old Aug 27, 2002 | 08:18 PM
DCmina's Avatar
Here are the ones I got
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1853317311
I put the red one in the red/black from the cluster and the black on black. Now it's on all the time. Oh well, It has a dimmer switch so that I can turn it off.
Man that S-AFC is gonna be a nightmare to install!
Thanks a lot!!
Old Aug 27, 2002 | 08:28 PM
TurboSmoke's Avatar
Getting Boosted
here are the ones i got
Old Aug 27, 2002 | 08:46 PM
DCmina's Avatar
I like them too but they are pricey!!
Old Aug 27, 2002 | 08:52 PM
TurboSmoke's Avatar
Getting Boosted
i only payed 50 for mine
Old Aug 27, 2002 | 09:57 PM
Icemark's Avatar
Thanks a lot!!
you can't get that red/black from the cluster, as I said on my post
There is no red/black at the cluster. Only a red/white (which is the feed from the high beam relay or the oil level sensor depending on what plug), and the above mentioned red/green that you should not use unless you want your indiglow gauges to burn out with too little voltage.
Th0m4s
Feb 26, 2019 02:04 AM
andyvideopro
Aug 20, 2015 10:55 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
