Sponsored by: CARiD
Rebuilding a GSL-SE
Old Aug 24, 2002 | 10:41 AM
Rebuilding a GSL-SE
I have a 84 GSL-SE that doesn't run and I don't know what is wrong with it but i am starting from scratch and i was wonder what is the best shop manual for the job.
Old Aug 24, 2002 | 11:03 AM
Ok, i have another problem. i tried to hook up the battery and i got the lights to raise and then all the power is gone and the battery is still good. i don't know what could have happened.
Old Aug 24, 2002 | 12:39 PM
diabolical1's Avatar
does it try to turn over at all when you turn the key?
i'm thinking poor ground or fried fusible links, but i'll need more info
Old Aug 24, 2002 | 12:41 PM
No it doesn't turn over at all, but it is not just starting the car but all other power is gone. None of the lights or anything will work
Old Aug 24, 2002 | 08:45 PM
sorry it is a 84 with a 13b engine
Old Aug 25, 2002 | 12:53 PM
okay ... well, it sounds like your fusible links then. check all of them, it might even be worth converting it to the Gen II fuse block ...
whatever you do, DO NOT just replace the links with wire or you'll be asking for trouble!
Old Aug 25, 2002 | 09:45 PM
Are there just two fuseable links? One bye the suspension mount and another by the steering column
i need to get another book
Old Aug 26, 2002 | 05:01 PM
to be honest, i don't know how many the SE's have (never had one) but i can say that the other Gen I cars had 3, so i'm guessing the SE's have 3 as well ... and yes, they are located on the left side strut housing (towards the front)
they should say something like ... headlamp, retractor and something ... (I forgot ... )
Old Aug 26, 2002 | 09:45 PM
rich367's Avatar
SE's have five fusible links on the driver's shock tower.
Old Aug 28, 2002 | 08:39 PM
Ok you guys were right and i pick up a fuseable link from the junk yard and it works perfectly Thank YOU
Old Aug 28, 2002 | 08:41 PM
ok i have another problem. Now my starter won't start running even when the key is out. So i took it out and took it to the auto parts store to have it checked and it works fine. so i put it back in and it work fine for about 5 start ups and now it is not working again. Any suggestions?
Old Aug 29, 2002 | 08:28 PM
not quite sure what you mean by this ...
if you're having sporadic trouble starting the car, i would say check your battery terminals, the ground wire connection to the block, or see if you need a relay in the starter circuit ...
but before you check or touch anything, explain what you mean, because i don't want to tell you something that might not be right based on my misunderstanding your question ...
Old Aug 29, 2002 | 11:11 PM
1stgenplayinrough's Avatar
i would grad a chiltons,haynes and the manuals that mazdatrix offers,
if you know your rx7 then a chiltons and haynes will do,
the haynes is good for everything but electrical,
thats where the chiltons comes in
Old Aug 30, 2002 | 08:42 AM
Ok, when the car is running the starter runs at a very high speed while not ingaged in the flywheel. so i took it off the car and took it down to the auto parts store and they could find anything wrong with it so i put it back on the car and it worked fine for about 5 starts then it began to run again. Somebody on said that it could be that the solenoid was stuck. i don't know though.
Old Aug 30, 2002 | 08:43 AM
oh no i have not trouble with the electrical.
Old Oct 14, 2002 | 11:27 PM
revn247's Avatar
was there a solution to this?
loganneet
Oct 3, 2015 07:51 PM
