What type of intake system do you have?
Old Aug 23, 2002 | 01:37 PM
Blade7's Avatar
Angry What type of intake system do you have?
I am sure there has been a poll on this, but I missed it!
And the search engine sucks!
please let me know, Am asking b/c quite frankly, I have an m2 and the fitment is horriable. I want one that will allow good flow but also fits nicely, Everyone's concept am sure. I just want to know what YOU 7 ethusiast have.
thanks in advance.
Old Aug 23, 2002 | 02:31 PM
Quik 93 FD's Avatar
going ls
i got the apexi power intake, fits real nice. the instructions sucked so i just slapped them in and they stay put.
Old Aug 23, 2002 | 02:35 PM
blackscorpio's Avatar
#1 F0RUM TROLL
I got modified Stock Airbox.
Old Aug 23, 2002 | 03:19 PM
From: Minnesota, now in FL and I dont think I'm goin back
I have the Blitz SUS intake, again the instructions sucked but its really a super easy insall. It also looks really nice, and does not wear out because it is mesh.
Mike
Old Aug 23, 2002 | 03:32 PM
jr's Avatar
jr
M2 Aluminum and the fitment is perfect.
Old Aug 23, 2002 | 03:45 PM
RyanREX's Avatar
Killer Turbo Twins
I made my own K&N filter charger one with exhaust pipes. Cost me under $100.
Old Aug 23, 2002 | 04:08 PM
R Xplicit's Avatar
home-modified pettit intake
Old Aug 23, 2002 | 04:33 PM
bajaman's Avatar
Constant threat
Modded stock airbox, with K&N drop-in.
Old Aug 23, 2002 | 04:39 PM
Vintage Red Touring's Avatar
I also have the Apex'i Power Intake. Looks great, works great, fits great. The only problem I have with it is I am limited in what Intercooler I can upgrade to when I upgrade.
Old Aug 23, 2002 | 05:25 PM
loi's Avatar
loi
hks race suction. very nice unit, come with polished tube.
Old Aug 23, 2002 | 05:36 PM
jpandes's Avatar
I had the RE Amemiya Intake, but was forced to get another intake when I got my Huge M2/ASP SMIC.
I made my own custom cold air intake using two 3x6" cylindrical K&N filters(the same as the ones used in the Pettit intake).
I also ran two 3" ducts from the nose of the car to the K&N's and fabbed an aluminum(polished) heat shield.
Old Aug 23, 2002 | 05:46 PM
user 84205's Avatar
A polished aluminum suction pipe, thats it..
Old Aug 23, 2002 | 06:03 PM
M2 aluminum, no problem at all. What is it about the fitment that sucks anyway?
Old Aug 23, 2002 | 06:06 PM
Chaz's Avatar
I have a similar custom K&N setup to RyanREX. BTW, the search engine doesn't suck too bad, there have been tons of posts on intakes recently. I was looking up a bunch of info within the past month and didn't have any trouble finding what I needed.
Old Aug 23, 2002 | 06:21 PM
GoRacer's Avatar
Speed Mach Go Go Go
I have the Blitz. I love the looks, the sound and response and it comes with a heat sheald.
If you want to do the "DIY" K&N deal. You can make it similar to the Pettit buy purchasing this RE Amemiya heat shield from jt-imports.com
Ack, stupid Netscape, damn firewalls.
You'll have to fo to the site and look it up.
Old Aug 23, 2002 | 09:30 PM
JspecFD's Avatar
M2 Carbon fiber, fits like a glove Installation can be tricky if you don't do some of the little things like removing the small side bracket.
Old Aug 23, 2002 | 09:37 PM
Blade7's Avatar
first, The bottom of the m2's box where the second turbo piping is surpose to go to is to low , thus makeing the rubber factory hose bend more than what is consider good. As a matter of fact, I think my motor may have went because of it. first the intake would bent under heavy throttle and all of a sudden the intake pipe would be reduce in efficiency, AND maybe that cause a problem. and so on .. Second the box should of been just a little bit bigger in demention so that the intake will have more area to take in air.
2cent
Old Aug 23, 2002 | 09:43 PM
beyondlimitz's Avatar
use to have the blitz sus. now using just one blitz cone on the gt35/45
Old Aug 23, 2002 | 11:07 PM
mecman's Avatar
I have a PFS intake. It has a large K&N filter in fiberglass box, so if you like to keep the air pump and BOV connected, it is quiet and improves flow quite a bit! My only complaint is that it is designed to hook into the PFS intercooler cowl, which I do not have.
Old Aug 23, 2002 | 11:11 PM
trigeek37's Avatar
PFS intake - it is a nice unit, but it is a major pain in the *** if you want to clean the K&N filter inside the cold air box.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
