Is my A/F gauge defective, or am i dumb?
Old Aug 22, 2002 | 10:13 PM
I Killed Tupac's Avatar
Question Is my A/F gauge defective, or am i dumb?
I intstalled an automete boost and A/F gauge in an A pillar pod today. For the boost, i used the open nipple on the intake mani, ran wires to battery ground and parking light relay for light.
On the A/F gauge (standard LED Autometer), i tapped the green wire with the red stripe on the harnes next to the main underhood fuse box (according to my multimeter, its is 12 volt ignition switched), grounded to battery, and the sensor wire is tapped directly in the to O2 sensor wire, about a foot off the O2 sensor itself.
Problem: The LED first showed stoich, but wouldnt move at all with acceleration. Then the LED's would stay halfway on sometimes, then they were very dim, but never really gave a reading, lean or rich
Is my gauge defective, or my install? Thanks!
Old Aug 22, 2002 | 10:29 PM
DK's Avatar
DK
40k worth of fail
Unless I'm reading retarded, which could very well be the case, your A/F install sounds theoretically matched up fine ... except I have a question. When you say that you grounded these things to the battery, do you really mean you ran a wire all the way to the battery? You do know how ground works, right?
And another thing, why run a power wire all the way to the underhood fuse box when the ignition switch is right there? It makes things so much easier ... and if you don't want to tap directly into the ignition harness wires with a ton of things, a really simple smart trick is to buy a $20 turbo timer harness for it and tap everything into there.
Old Aug 22, 2002 | 10:47 PM
There's an ignition switch right under the damn dash?!?! Awwwww! I dont really know much about FD's specifically, but boost gauges and A/F gauges are pretty much the same install in most cars. Power, ground, and O2 sensor splice.
I had to run the vacuum line for the boost gauge through the firewall anyways, and there is already a conduit there for my amp power wire anyways, so it was real easy. Where is this ignition switch you speak of? Its hard to find anything under my dash now anways cuz its now so full of wiring and electronics (tv screen AV center, alarm, gauges, TV antennas, PS2 wires, DVD player crap, etc)
So is your vote for a defective gauge then? Has anyone else used the Autometer AF gauge?
Old Aug 22, 2002 | 10:52 PM
RonKMiller's Avatar
Blow up or win
They are all defective.
Old Aug 22, 2002 | 10:53 PM
RonKMiller's Avatar
Blow up or win
Oh ****, he made fun of DK. Everyone DUCK!
Old Aug 23, 2002 | 02:03 AM
I did? That's cool, i'm always down for a flame war
But before we engage-what do you think of this theory?
I wired the 12V swithed supply for the AF gauge to a harnes that showed 12v when the key was one. But, when running, it looks like maybe that wire isnt giving enough juice for the meter to read right. Does that make sense? And what wire is the ignition wire under the dash? That would be sweeeet
Old Aug 23, 2002 | 02:17 AM
pluto's Avatar
Re: Is my A/F gauge defective, or am i dumb?
Sounds like your O2 sensor is dying to me. typically a dead O2 sensor will first goto stoich and then to lean condition soon after. Thats why cars with bad O2 sensor always run rich because its telling the ECU it's running lean and needs to dump more fuel.
Steve K
Old Aug 23, 2002 | 03:28 AM
Hyperite's Avatar
Vagina Junction
Try splicing the big black wire with a yellow stripe going to the ECU. It's been like 2 years since I installed mine, but I think that's the right wire. It's a little thicker than the rest and I'm SURE it was either all black, or with a stripe. Probably with a stripe since all black usually means ground.
~Tom
Old Aug 23, 2002 | 03:45 PM
Originally posted by Dont_Be_A_Rikki
Sounds like the sensor has had it last day.
that would explain why i'm idling funny and getting approximately 8 mph this tank!
Old Aug 23, 2002 | 05:51 PM
R Xplicit's Avatar
~Tom
i also vote for the O2 wire off of the ecu. i had the exact same results when i tapped into the o2 wire itself. it is insulated, and very hard to get a good connection....
louis
Old Sep 12, 2002 | 03:23 PM
so this wire is the one going directly into the ECU itself? Black with a yellow stripe? There's 4 plugs total going into the ECU-which one?
Old Sep 12, 2002 | 03:38 PM
Orange!FD's Avatar
WOW that is slow. I bet people honk.
Old Sep 12, 2002 | 05:49 PM
black with yello stripe does nothing.
Old Sep 12, 2002 | 05:55 PM
r0t0r-rooter's Avatar
call me Smokie Smokerson
I think he meant 8 mpg.... not 8 mph
Old Oct 19, 2002 | 11:07 PM
coop's Avatar
Originally posted by Steak & Cheese Please
You will find that a standard A/F gauge does not read RICH conditions at all. It is good for idle and stoich. If you try to tune with that you will pop or come very close. Most A/F gauges read 12:1 so if anyone tunes to that they should be shot unless it is done on a high quality race fuel. If I were you I would get a 5 wire lamba sensor and a wide band and tune to 11:2.1 and nothing more.
Just my take
What do you mean that it doesn't read Rich, is it just that it never reads a 'true' rich no matter what the LED meter on the A/F gauge reads?
Can you use a WB-O2 with the A/F meter to get accurate readings for tuning?
Old Oct 19, 2002 | 11:12 PM
coop's Avatar
I just wired a 12VDC relay into the power wire for the radio so I have a point to wire to the ignition switched 12vdc. Works nice, don't have to get into the dash (other than behind the radio), costs about $2.50 at radioshack
On another note, does it help at all to clean the tip of the O2 sensor? I figure it wouldn't unless the tip was gunked up, but I didn't know if anyone has any other experience....
Old Oct 20, 2002 | 03:31 AM
GsrSol's Avatar
Z06 powered FD
That was funny as hell!
Back to the topic, I've never liked autometer gauges but you need to find out what LED's are what ratio. And go ahead and replace the O2.
Old Oct 20, 2002 | 03:33 AM
skunks's Avatar
I'm a CF and poop smith
get on a wideband, that being said, the stock O2 sensor and a/f ratio gauge will only work (haha, i would not even consider this really working) at WOT.
good luck
Old Oct 20, 2002 | 08:48 AM
13brv3's Avatar
This may be a dumb question, but can a multiwire wideband O2 sensor be made to work with the stock ECU, or even the PFC? I imagine you'd still need a controller for the wideband, but could you pick off a signal wire from the sensor or controller to keep the ECU happy?
Thanks,
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
The1Sun
Sep 18, 2015 07:13 PM
kryan9
Sep 15, 2015 10:11 PM
The1Sun
Sep 15, 2015 04:45 PM
t-von
Sep 10, 2015 01:56 PM
