autolites 2626 have to be side fire converted Right? or...
Old Aug 22, 2002 | 03:05 PM
Hans's Avatar
are they short enough to stay top fire, I figured they have to be converted, but havent seen a 'set' answer.
also .050 for leading and .085 for trailing is what Yaw has, any luck with this setup, sound close?
thanks
Old Aug 22, 2002 | 05:43 PM
rotarygod's Avatar
Rotors still spinning
Convert them to side fire. If you don't the apex seals will hit them. Gaping is about right but experiment here. I hope you have some form of direct fire. If not they probably won't work as good as the stock plugs. Be careful with those autolites. They have a VERY short lifespan. Be careful the ceramic doesn't crack and fall through the engine. I had 2 plugs do that on my old 2nd gen motor. Still ran but when I rebuilt it I could see exactly which plug had broken just by looking at the rotor housings. With a direct fire system the power increase is impressive for the amount of work and money involved. I've had better luck with NGK BP7ES plugs converted to side fire. I buy them at a local motorcycle shop for a few bucks each. They are what is currently in my GSL-SE. I only use them on leading and use 2nd gen plugs on trailing.
Old Aug 23, 2002 | 12:47 AM
Damn, i never thought about apex seals hitting the top of a plug. That would suck.
diabolical1
30
Jan 30, 2016 05:50 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Ninja636
Aug 19, 2015 01:52 PM
Professorpeanutrx7
Aug 18, 2015 03:09 PM
