what should i do along with rebuild??
Old Aug 20, 2002 | 09:39 PM
jeff8932612's Avatar
Question what should i do along with rebuild??
Hi,
I am beginning to plan what all i want done when i get my engine rebuilt. ( i know it should be happening soon cause i got 109k on the original!!!) Anyways..my goal is to get a strong...not supersonic...and more reliable engine than stock. Right now i am looking at 2mm hurley seals, rebuild at pineapple with mild streetport and oil mods. I also plan to get my vacuum hoses changed. WHat else do you all recommend i should do to help the reliability and power of this motor. I dont want anything outrageous fast...just a little faster than stock. Maybe like 300 rwhp or so. Some people mentioned upgrade the fuel system with parts like better fuel pump, bigger injectors, comp., etc. WHat do you think? And please recommend specific companies and their products so i can begin compiling my "wishlist" ? My current mods are listed below. THanks alot guys!
-Jeff
Old Aug 20, 2002 | 09:42 PM
and if i get it ported...will i still be able to buy a piggyback comp for my car? Or can only the stand-alone units support ported engines?THanks
-Jeff
Old Aug 20, 2002 | 09:49 PM
GoRacer's Avatar
Speed Mach Go Go Go
Change the engine mounts, since the engine is out.
BTW: There was another thread exactly like this maybe a month ago. I'm all searched out for the day.
Old Aug 20, 2002 | 09:50 PM
the_glass_man's Avatar
Will u do me a kindness?
I would get a Apex'i PFC or the new AEM, and find someone that can tune it for you.
While you engine is out, upgrade to an ACT clutch and a lightweigth flywheel.
While your at it upgrade the radiator and replace the hoses and clean the engine bay.
Old Aug 20, 2002 | 09:53 PM
what about the fuel system? should i go for bigger injectors and pump? I would like to get the PFC but i live near New Orleans. I dont know of anybody who can tune rx-7's around here.
Old Aug 20, 2002 | 09:56 PM
Silex's Avatar
What glassy said and plus maybe a new intercooler with aluminum end tanks and also make sure you did all of the reliability mods (ast, dp, boost gauge, etc.).
Old Aug 20, 2002 | 09:57 PM
Silex's Avatar
That's not even super important yet until you go aftermarket turbos. Trust me, the radiator and intercooler (if you decide to get them) will set you over the top enough as it is (~$2k total) so just leave it at that .
Old Aug 20, 2002 | 10:08 PM
boomer,
what did you mean when you said.."will set you over the top enough as it is". Where you referring to budget? or the reliability those mods (intercooler and radiator) will add? Thanks for all the help guys!
-Jeff
Old Aug 20, 2002 | 10:12 PM
If you just plan on having 300-330 rwhp, you don't need to upgrade the fuel system, but if you are power hungry(and who isn't) upgrade the pump and the injectors.
I don't know how much your budget is for something like this, just the engine is going to set you back some coin.
Its kind of vague, I could tell you its a good time to go single turbo, FMIC, BOV, Polish everything etc...
Old Aug 20, 2002 | 10:17 PM
cmartinp28's Avatar
get a better radiator, and a better temp guage
i am looking more for reliability than speed. i already did all the no-brainer reliability mods...i was wondering what parts i should get along with my engine are good for reliability. Lets call it stage 2 or stage 3 on the reliability list. STage 1 can include boost gauge, ast, turbo timer, etc....
Old Aug 20, 2002 | 10:34 PM
New Radiator and Thermotec hoses, you may want to switch to Evans as well.
New Silcone Vacuum Lines.
New T-Stat.
Down Pipe.*** The Fist mod anyone should do.
Highflow car or Midpipe and a catback.
Large SMIC.
Have primary injectors cleaned and balanced.
1300 CC Injectors.
Supra Fuel Pump.
Power FC.
Vented Hood.
New Engine Mounts.
Torque Brace.
New Flywheel.
New Clutch.
New Fule Pulsation Damper.
Relocate Fuel Filter.
That good enough for now???
Old Aug 20, 2002 | 10:35 PM
You should also look at your turbos and think about having them rebuilt or refreshed as well. Its not too hard to do it yourself, but its something worth checking into.
Old Aug 20, 2002 | 11:28 PM
ttb's Avatar
ttb
No Cup Holder Racing
wow, 109k miles on original..how's it running? i'm at 102k miles. i'm planning/saving as well. i think it's going to cost me around 6k for the rebuild. what mods do you currently have?
ttb's Avatar
ttb
nevermind, saw our sig
Old Aug 21, 2002 | 12:05 AM
mmonaco's Avatar
Part out my Car
3mm seal. WHat the hell are you saying go with 2mm. YOu must be stupid go with 3mm. But stock 2mm are way better. I could do this for ever.lol.
Marc
Old Aug 21, 2002 | 04:12 PM
mmonaco,
I have heard that the 3mm seals may be more durable but they do not seal as well as 2mm seals. Plus dont you have to machine the rotor so the 3mm seal will fit?Which seals do you guys prefer? Thanks.
-Jeff
Old Aug 21, 2002 | 04:53 PM
2mm
Old Aug 21, 2002 | 04:55 PM
mmonaco's Avatar
Part out my Car
YOu are right on the info you put forword. IF you are going to tune your engine yourself go with 3mm, if you are having someone tune your car then go with 2mm. Eithor way bad tuning is bad tunning. I went with 2mm cause it was i felt was the better seal. and yes you have to machine the rotor to fit 3mm. IT all up to you. there are manty poeple runing 30+ psi on stock 2mm seal and have had and having great results. Theres a big thread on the pros and con so do a search.
Marc
Old Aug 21, 2002 | 04:58 PM
Mr. Stock's Avatar
1993 RX7 R1
Dude,
You need a downpipe.
And also get a coolant temp gauge installed.
Old Aug 21, 2002 | 05:09 PM
Originally posted by Mr. Stock
Dude,
I believe he has a Water Temp gauge, and I agree on the downpipe, its one of the fist mods anyone should do.
Old Aug 21, 2002 | 05:15 PM
Mr. Stock's Avatar
1993 RX7 R1
My bad!
Sorry, I read the mod list too quickly.
However, the downpipe is a glaring omission on your mod list.
Old Aug 21, 2002 | 08:28 PM
yeah, i am definitely going to get a downpipe when i get my engine done. i am wondering if i will need a new computer if i get my engine ported and install a downpipe. Cause i already have intake....that'll make 3 power mods....
Old Aug 31, 2002 | 03:43 AM
Flyrx7's Avatar
Money Pit
Having just done this 8 months ago, here is what I did:
**Replace all coolant hoses
-Magnecor plug wires
**Upgrade radiator
-Send out injectors to be sonic cleaned and balanced
**Replace all vacuum hoses with Viton tubing and tie wraps
-Send out turbos for rebuild, but they're probably all cracked to hell in the turbine housings (can't see unless you take them apart) so this may be $$
**Flush heater core completely and replace coolant with Evans NPG+ (used 7# rad cap)
-powder coat/paint/chrome/polish misc brackets and fittings
**Replace fuel filter (if you don't know when it was last changed)
Clean everything (all parts and engine bay)
-aluminum AST (you have already)
-water temp gauge (you have already)
-new PS and ALT belts
-Plan ahead for future mods, if you are adding more power, get a clutch. Think about the parts that are easy to reach while the engine is out (clutch, turbos, engine mounts, 5th gear synchro, under drive pulleys, coils and weigh your pocket book vs the effort to take care of these items later.
(** items are top priority) IMHO
You will be amazed at how much this is gonna' cost you, so prioritize. Planning can go a long way, so make a list of all your parts, cost them out, there will be some unexpected costs so factor in a cushion, and don't forget shipping costs. Keep a log with suppliers, contacts, phone #'s and web addresses, and nescesary parts list as well as a wish list.
Have fun!
Frank
Old Aug 31, 2002 | 06:19 AM
rotorbrain's Avatar
fart on a friends head!!!
IF YOU ARE PORTING YOUR ENGINE THEN YOU NEED SOME SORT OF ECU TUNING EQUIPMENT. i say piggyback schmiggyback. . . get the real deal. youll love it. . . power fc or aem. that aem looks to be the way to go. IMO the stand alone ecu IS a reliability mod.
paul
Vartok
16
Oct 8, 2015 04:49 PM
NickNac113
13
Oct 1, 2015 09:25 PM
musker
Oct 1, 2015 05:58 PM
