what to spend my money on
Old Aug 19, 2002 | 01:10 PM
statikphreeze's Avatar
ok i am getting my fd very very soon and i have 4g's to spend on it apart the the "reliablity mods" which i already know what they are and i figured that they would cost me about 1k what do i spend my other 3 grand on i want to really boost up the hp and emmisions is not a problem i have a friend who if i hook him up with 50 bucks he says he will over look anything that would make my car not pass inspection please reply and try not to flame me to much
Old Aug 19, 2002 | 01:13 PM
ttpowerd's Avatar
HARRRRRRRRR
dp,cb,intake,ecu,mp,ic,fuel pump,injectors
$200,400,300,1000,200,1000,250,330=$3680
Old Aug 19, 2002 | 01:16 PM
ttpowerd's Avatar
HARRRRRRRRR
That should be good for about 330-350 rwhp if you bump up the boost. Sorry for the abbreviations:
dp= downpipe
cb= catback
ecu= engine control unit
mp= midpipe
ic= intercooler
That should take care of hp increases at first. Then I would look into suspension and whatever else suits your needs. Make sure to get those reliability mods first though!
Old Aug 19, 2002 | 01:19 PM
RX7Elmo's Avatar
i would also put asside money into changing all the fluids with some good synthetics, how are the tires, brakes, also the fuel filter, spark plug wires, spark plugs. how are the shocks?
Danny
Old Aug 19, 2002 | 01:53 PM
the_glass_man's Avatar
Will u do me a kindness?
Welome to the world of the money pit or RX-7.
Old Aug 19, 2002 | 02:05 PM
Mahjik's Avatar
Mr. Links
Danny
I agree. Don't worry about making more power just yet. Get all the fluids and filters changed, and look at the suspension. If it's the original suspension, it's probably in need of some replacement.
Tires is also another great suggestion. These cars need all the help they can get sticking to the road since they are light weight with good power.
Old Aug 19, 2002 | 02:07 PM
GsrSol's Avatar
Z06 powered FD
Why are all you people into performance?
Here you go
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1851603952
Old Aug 20, 2002 | 06:55 AM
duchi's Avatar
i'd say if the radiator is not included in your reliability mods budget or hasn't already been replaced, it and the thermostat along with upper and lower hoses should be replaced. make sure the jiggle valve on the t-stat remains at 12 o`clock. also, upon removal of the thermostat, try to check to make sure the previous owner didn't put/use block seal or linseed oil to seal coolant leaks that would build up around the fan thermoswitch and prevent it from reliably sensing the coolant temps. iirc the sensor is one of 2 in the rear of the same housing.
Old Aug 31, 2002 | 03:56 AM
Flyrx7's Avatar
Money Pit
Don't forget gauges man! You need to monitor your vitals if you go beyond stock.
-Boost
-Water temp
-Fuel pressure
-Exhaust gas
-Air fuel ratio
-Oil temp
-Oil pressure
Pretty much in that order, some may disagree, but the first 2 I think everyone will agree on.
And since you have some coin, I'll sell you a gauge pod to hold em' in Check em out at
Regards,
Frank
Sethix
Nov 3, 2017 11:48 PM
joel(PA)
Oct 4, 2015 06:07 PM
