Low Power, Need Help!
Old Aug 19, 2002 | 10:47 AM
Borch's Avatar
Here's my story.....
This year, I have installed a new Adkins ported engine and JSpec Turbo's. I also installed a new O2 sensor.
Last year, Downpipe, Catback, Hi Flow Cat, ECU, Intake, Boost guage, Profec B.
I think I should have 275 - 300rwhp at this point. The boost is ramping up quickly and is in an 11-9-11 pattern.
The power feels less than when she was stock.
Any ideas on where to look for my problem?
Old Aug 19, 2002 | 12:00 PM
Jim Calandrella's Avatar
The Ricer Eliminator
Feels less, or IS less..........? Do you mean power across the whole rpm range?
Old Aug 19, 2002 | 12:06 PM
Borch's Avatar
Is less. Yes through the whole range.
It is actually the worst when in 4th gear and about 3500rpm's. Really slow acceleration.
Old Aug 19, 2002 | 12:19 PM
Hmmmm.... I've had this problem before. I'll think about this for a while. For now, check your plugs and wires. I'm not sure which plug it is, but if one of them goes bad, you'll still show that your making boost, but you won't be going anywhere. This also happens if wires are reversed.
Good luck.
Jim
Old Aug 19, 2002 | 12:21 PM
Borch's Avatar
I had a reputable FD mechanic out of Indianapolis install the motor, but I'll check on the wires. He installed new plugs when he did the motor swap 2 months ago.
Old Aug 19, 2002 | 12:23 PM
I'll keep thinking. Until then. Good luck.
Jim
Old Aug 19, 2002 | 12:30 PM
Borch's Avatar
Thanks!
Old Aug 19, 2002 | 02:14 PM
JspecFD's Avatar
Try doing a dyno run so you get some qualitative data on how much power you're putting down across the range.
Old Aug 19, 2002 | 02:40 PM
redrotaryrock8's Avatar
could it be the clutch??? or the flywheel???
Old Aug 19, 2002 | 04:16 PM
If it were the clutch, wouldn't you smell it? I know it didn't take much to make my stock one smell. I guess it's as good a guess as any at this point.
The dyno idea is a good one.
Jim
Old Aug 19, 2002 | 08:17 PM
Borch's Avatar
No smell from the clutch.
I did have an upgrade fuel pump put on today. Test spin tomorrow.
Old Aug 20, 2002 | 03:33 PM
I wonder if it could be a leak of some sort. Your boost comes up quickly?
Old Aug 20, 2002 | 03:53 PM
Borch's Avatar
No leaks that we know of. The boost is quick. I also had a silicone hose job done this year as well.
Old Aug 20, 2002 | 04:09 PM
Dammit! This is pissing me off. I had this problem 2 years ago. Motherf%*^$
Old Aug 20, 2002 | 04:52 PM
Borch's Avatar
You think your pissed? I have missed 3 driving events, spent $10,000 on the car and new trailer and can't figure out why it doesn't have power. This is definately a love/hate relationship!
Old Aug 20, 2002 | 08:50 PM
Borch's Avatar
What do you think about the ECU being bad? I install a Pettit upgraded ECU last year.
Old Aug 22, 2002 | 01:34 PM
Borch's Avatar
Put an A/F guage on, looks good.
Will try to trade out the ECU to see if that may be the problem
Old Aug 22, 2002 | 03:03 PM
Borch's Avatar
Switched out the Pettit ECU with an M2. No difference.
Could it be the knock sensor?
Old Aug 22, 2002 | 03:30 PM
I'm not sure the knock sensor would have anything to do with it, but if you have an appropriate test for that sensor, it's worth a try.
Could this be ignition related? Like a bad coil or something?
Old Aug 22, 2002 | 07:56 PM
Borch's Avatar
We checked the coils, and they are fine. This is getting f'ing rediculous!
Old Aug 22, 2002 | 09:26 PM
There are only so many different areas to look. Why aren't we stumbling onto this? You checked ECU, you checked some ignition components, your turbos are not old, you don't have a boost leak, and your clutch isn't slipping. What else could affect power? The thing that is intrigueing is that you're showing correct boost levels. I'm convinced that this is your key.
Assuming your boost readings are correct, we have to find what other things factor into power delivery.
I'm sorry man.
This must be driving crazy. I'll keep asking around.
Good luck
Jim
Old Aug 23, 2002 | 09:31 PM
Borch's Avatar
I'm sorry man.
Good luck
Jim
Feul, Fire and Timing. That's the things I can think of. The A/F ratio seems fine. Has to be the fire or timing.
Old Aug 27, 2002 | 06:16 PM
Borch's Avatar
Talking
Turns out, it was the leading coil.
Gonna pick her up on Thursday and take her straight to Putnam Park Road Course for a 3 hour lapping session celebration!
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
20B Forum
Aug 30, 2015 12:08 AM
