Suspension for 1988 AE?
Old Aug 19, 2002 | 08:20 AM
jetfire76's Avatar
Gas Guzzlin' Tire Junkie
quick question...
what was the stock suspension on a 1988 10th anniversary edition? was it adjustable w/ ABS? not adjustable w/ ABS? adjustable w/o ABS? or just ABS?
thanks in advance!!
Old Aug 19, 2002 | 08:25 AM
eViLRotor's Avatar
Brother of the Rotary
AAS and ABS!
Old Aug 19, 2002 | 08:28 AM
jetfire76's Avatar
thanks!!!
Old Aug 19, 2002 | 09:01 AM
DaleClark's Avatar
RX-7 Bad Ass
The 10th Anniversary had the "hard" suspension, NO auto-adjusting suspension. ABS was an option, but most 10th's I've seen didn't have ABS.
I'm assuming you're trying to get a part for your car and they asked you that - what are you trying to get?
BTW, the auto-adjusting suspension was ONLY on the GXL's in the US. It was on the higher-end models in Japan.
Dale
Old Aug 19, 2002 | 09:09 AM
eViLRotor's Avatar
Dale
Strange.
All the CDN AE's I've seen had ABS.
And even my 87 TII had the AAS!
Different markets I guess...
Old Aug 19, 2002 | 10:01 AM
jetfire76's Avatar
i need to replace the brake master cylinder. i have all these choices and i'm not sure what i need.
Old Aug 19, 2002 | 10:36 AM
DaleClark's Avatar
RX-7 Bad Ass
Check to see if your car has ABS - that's the big factor. If you do, there will be a BIG pump with brake lines coming to/from it on the passenger side of the engine bay near the firewall.
If you have AAS, you will have a switch in the center console to pick between normal and sport suspension modes - I doubt that, though.
I highly recommend getting a new Mazda part as well - I've had bad luck with cheap rebuilt master cylinders.
Dale
Old Aug 19, 2002 | 10:38 AM
DaleClark's Avatar
RX-7 Bad Ass
Originally posted by eViLRotor
Strange.
That's odd - are you sure the '87 TII had AAS? That may be a Canadian market thing or something. I know the '87-88 TII's in the US had the electrical plugs there for AAS.
Again, the ABS was an option with the 10th Anniversaries, but *most* I've seen didn't have it, but I do seem to remember seeing 10th Annies with it.
Dale
Old Aug 19, 2002 | 11:26 AM
FC3S_MI's Avatar
My tenth doesn't have AAS or ABS.
Old Aug 19, 2002 | 12:34 PM
eViLRotor's Avatar
Dale
Again, it could be a Canadian thing.
But my current 87 TII has the AAS system buttons with the normal and sport settings. I don't have the OEM suspension anymore though, so its disabled.
Anyways, you guys own AE's, so you're the experts!
Coochas
44
Nov 5, 2019 11:08 PM
yr6
Oct 4, 2015 12:23 PM
Postman09
Sep 29, 2015 11:23 AM
