? on install of 99 winkers
Old Aug 18, 2002 | 04:06 PM
allrotor93's Avatar
what is the best way to install them? do i need a special harness? i could not come up with anything in the search. thanks in advance.
Old Aug 18, 2002 | 05:01 PM
Crashunit's Avatar
MIA
just cut off the wires form your original harness and rewire them. You can search and find the same answer.
Old Aug 18, 2002 | 05:51 PM
allrotor93's Avatar
i could not find out what to search for. can you post the link to the installation thread? thanks.
Old Aug 18, 2002 | 07:03 PM
Crashunit's Avatar
MIA
I dont think there is an istallation thread on it, its pretty stright forward if you have your stock harness and get the 99 spec turn signals with the bulbs. If you have any type of experience (basically cutting and soldering) working with electrial wires its a no brainer. If you have the 99 blinker, just compare it to your stock one, there are three or four wires that go to the same bulbs as the 99 ones. Your stock ones just dont fit in there cause the socket is a diffrent pattern, but they are basically the same thing.
Old Aug 18, 2002 | 08:37 PM
manatecu's Avatar
Its real easy to figure out. There is one wire that goes to both lights on the older lights. That wire is the ground. I would get three female electrical ends from autozone, well I guess you would need a box, 3 for each side and do some testing until you got it perfect. Crimp them on after testing the turn signal and hazards. Them use some black silicone and fill up the hole so the connectors will not pull out.
Chris
Old Aug 18, 2002 | 08:59 PM
allrotor93's Avatar
lights
ok. thanks for the help. i haven't really looked at it, just wanted some knowledge going into the installation.
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
