Dual alt. pulley install
Old Aug 15, 2002 | 07:56 PM
Hello,
I have the dual alt pulley from bonzaitoyota and was wondering how the heck do I get the bolt of for removing the single pulley so I can put the double one on.
Any help would be great....... Thanks,
Benny
PM me if you want instead.
Old Aug 15, 2002 | 08:02 PM
banzaitoyota's Avatar
What Subscription?
Installation is SIMPLE:
remove pulley nut with a 22MM socket on an impact wrench.
Remove old belt and pulley halves.
Install new pulley and use your old washer and pulley nut
Loosen Alt adjustment bolt
Install 2 new alternator belts
Adjust tension on new belts
Tighten tension bolt
Tighten 22mm nut using impact wrench.
If you do not have an impact wrench.
Remove alternator from car
Take to your neighborhood
Go to autozone or advanced auto and ask them nicely to install the pulley. They have an electric impact wrench
It helps if you buy your belts there!!!!
Any questions give me a shout. John
Old Aug 15, 2002 | 08:04 PM
RestoTII's Avatar
If you have an impact wrench (or any air tools), they make the job just plain simple. I just hit it for about 1-2 seconds and it was off. If not, you might want to try to break it loose while it's still tensioned by the alt belt, but it might be kind of tough without air tools. I didn't try without, but I'm assuming the belt would slip before it breaks loose if you don't use air tools.
Old Aug 15, 2002 | 08:12 PM
thanks guys,
I'll bring it to the auto store and hopefully they will do it.
Benny
Old Aug 16, 2002 | 07:50 PM
thanks it's on the guy down the street with an impact gun did it. I gave em 5$ i'll be back someday...lol
LunchboxCritter
15
Jan 3, 2016 04:11 PM
rotor_veux
Aug 31, 2015 07:49 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
