Sponsored by: CARiD
motor compatibility question
Old Aug 14, 2002 | 11:25 PM
jjd2's Avatar
will the second gen 13 b rotors and rotor housings fit on the third gen e-shaft and steels or are the bearings and thru bolt patterns different?
thanks, jjd2
Old Aug 15, 2002 | 11:19 AM
j9fd3s's Avatar
Community Builder
you might want to check the bearing clearances, but it should work fine
mike
Old Aug 15, 2002 | 11:50 AM
peejay's Avatar
Old [Sch|F]ool
series 5 and series 6 (late 2nd gen and early 3rd gen) rotors are identical in weight and compression ratio and are totally interchangeable, the difference is the series 6 rotors have a fully machined bathrub and the earlier ones are left partly cast.
hotshot2014
Jul 18, 2017 02:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
