Porting Template for 6 port 13b
Old Aug 11, 2002 | 07:03 PM
JIMMY54's Avatar
GSL-SE PRO
According to Racing Beat there is a certian way to port a 13b 6 port. Has any one out there done this before, if so can someone scan the templates? I have a spare motor laying around and i wanted to try porting myself.
Thanks
Old Aug 11, 2002 | 08:05 PM
WackyRotary's Avatar
standard combustion
They have them avaliable at Mazdatrix. Not too many people do it to a 6port since not too much in gains can be made. Good luck finding "used" templates.
Old Aug 11, 2002 | 11:10 PM
JIMMY54's Avatar
GSL-SE PRO
What do you mean there isn't much gains? So its more effictive on a 12a than 13b?
Old Aug 11, 2002 | 11:39 PM
standard combustion
Let me re-state what I said better, 13b 6port engines could be built into amasing engines with loads of cash. But with porting alone, mild gains only. Meaning, only do it if the engine is seceduled to be apart anyway. While your at it, order the Pineapple Racing sleeves for the 6ports since they flow better. I don't know what the increase is, but it would help.
12a engine as a base for porting is a little different. They can be made into mild, extend, bridgeport, j-port, monsta port. A 6port could be made into some thing else, but so little is done by people, that there isn't much info on it. People mod TII's and 4port engines more.
Where as the 6port, keeping it functional with 6ports is not going to yield 250hp. More like 180-200hp typically depending on the things you do. Say a '91 6port with pineapple racing sleeves, mildported, mazdatrix full dual exhuast, high flow air filter, and light flywheel will be a relatively fun engine(~200hp.)
Old Aug 12, 2002 | 08:39 AM
JIMMY54's Avatar
GSL-SE PRO
Really, thanks for the infomation...
The engine is gonna be torn apart anyway so why not, I'll keep everyone posted as time goes by.
Old Aug 12, 2002 | 11:21 AM
Directfreak's Avatar
I am a Jeeper Now.
http://www.mazdatrix.com/faq/port6p.htm
Old Aug 12, 2002 | 02:24 PM
JIMMY54's Avatar
GSL-SE PRO
wicked Directfreak, thanks for the pics
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
mulcryant
Sep 9, 2015 05:24 PM
Ian_D
Sep 6, 2015 10:38 PM
