replace belt
Old Aug 8, 2002 | 04:53 AM
jack pang's Avatar
Question replace belt
Hi!
Everybody i want to replace the two belt.
i am already order Greddy pully set but i don't know which belt i need buy? (another Belt)
Who Can show the graph to me?
Old Aug 8, 2002 | 05:23 AM
skunks's Avatar
I'm a CF and poop smith
that greddy kit should come with a new belt.
Old Aug 8, 2002 | 06:50 AM
ttpowerd's Avatar
HARRRRRRRRR
This is a diagram of the belts:
The greddy pulley kit is for the elimination of the air pump. They send you a small belt that only runs the water pump and altenator.
Old Aug 8, 2002 | 06:53 AM
ttpowerd's Avatar
HARRRRRRRRR
and here is the belt that comes with the greddy pulleys:
Old Aug 8, 2002 | 09:41 AM
jack pang's Avatar
thankyou very much ttpowerd.
But how to install the original belt?
i need buy a new belt for air pump
Old Aug 9, 2002 | 12:04 AM
pnoy1duh's Avatar
In a girl car.
if you still want to use your air pump, use this belt:
Gates K050551
it can be found at a car quest, its a tough belt to find, you'll probably have to order it and its nearly 20 dollars,
p.s.
expect alot of adjusting
Old Aug 9, 2002 | 01:02 AM
Kahren's Avatar
i am not a girl
when u guys remove the air pump is that how it runs, going from the alretnator to the main pulley? and the water pump gets only very little surface area of the belt this doesnt look good. i would be afraid of it slippiing does this happen? does anyone run it in a diffrent way?
Old Aug 9, 2002 | 01:09 AM
pnoy1duh's Avatar
In a girl car.
if everything is adjusted tight enough and there is no slack, you should be fine...i cant imagine any other configuration as the pulley would go in the opposite direction
Old Aug 9, 2002 | 07:04 AM
ttpowerd's Avatar
HARRRRRRRRR
Well I did not do a very good job on the picture, making it to spec but the new pulley over laps the maindrive pulley more. So there should be a good bit of contact made between the belt and the water pump pulley.
Old Aug 9, 2002 | 11:31 AM
pnoy1duh's Avatar
In a girl car.
lol, to the original poster
i'm sorry, there probably is no car quest in hong kong
oops
t-von
Sep 10, 2015 01:56 PM
SCinfidel
Sep 8, 2015 05:36 PM
