Those who did block seal
Old Aug 6, 2002 | 10:50 AM
DHALL's Avatar
Avatar courtesy of SexyRX
I have already searched, but I need some more info from those who did it. Did you drain the whole coolant system(from the radiator and from the drain plug under the car?) I have heard that you shouldn't drain the rad. ever. Also did you have to take out the thermostat? I read that someone had done that. If you could, would you show exact procedure and the outcome. I really appreciate it.
Old Aug 6, 2002 | 01:14 PM
pomanferrari's Avatar
Dude,
I did a report on this with detailed instruction. I removed the thermostat otherwise it takes forever to fill and warm the car up. Figured a shortcut to this.
1. loosen the alternator belt;
2. use a 1/4 drive and 10mm socket
3. tape the socket to a 6 inch extender with electirical tape so the socket doesn't fall out when you insert it into the space b/w the airpump and the themostat housing;
4. remove the three bolts and remove housing
5. remove thermostat;
6. clean thermostat housing with a angled buffer
7. attach the housing;
8. do the block weld;
9. replace thermostat. DONOT DRIVE AROUND WITHOUT A THERMOSTAT.
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
jakeishness
11
Sep 11, 2015 11:33 AM
