How do i install a pilot bearing?
Old Aug 5, 2002 | 05:01 PM
ejmack1's Avatar
Lawn Ornament
Just get a hammer and start pounding or what?
Old Aug 5, 2002 | 07:22 PM
Blackbeast's Avatar
I use a socket with the same size diameter, gently tap it in with a rubber mallet. make sure you put some insulation between the contact of the socket to the pilot bearing. The bearing is I think copper and easy to be deformed if it's pounded too hard.
Timmy
Old Aug 5, 2002 | 07:31 PM
RonKMiller's Avatar
Blow up or win
My first question is how did you get the old one out?
Without a special Mazduh tool it is just about impossible to do without damaging something..........If it was damaged you might be wasting your time putting in a new one.
Old Aug 5, 2002 | 09:23 PM
duboisr's Avatar
you can get the old one out with a bearing puller or puller on a slide hammer , if you do not have the correct puller get a die grinder and small stone and cut the bearing out , the shell is steel not copper . Clean the hole oil the new bearing and tap it in with a socket ,grease the rollers and tap in the seal
Old Aug 5, 2002 | 09:56 PM
Wargasm's Avatar
Weird Cat Man
To help installation, I freeze the bearing in the freezer overnight and then take it out of there and immediately install it. I use a socket as my "driver" to pound it in there with the hammer. Use some grease too.
B
Old Aug 5, 2002 | 11:11 PM
ejmack1's Avatar
Lawn Ornament
Well seeing i had an auto... I didn't have one to take out in the first place... thanks guys.. i used a socket and gently tapped her in there.... all i need now is the clutch cover bolts and my conversion will be almost complete
tiger18
Sep 3, 2015 08:27 PM
rx7jocke
Aug 15, 2015 03:36 PM
