Help, Boost Pills
Old Aug 5, 2002 | 03:35 AM
Rotormania's Avatar
Help, Boost Pills
hey guys,
Do you know the part number if any for the two hoses that the boost pills are, or If you have a spare set that you want to sell let me know.
Thanks,
Charris
Old Aug 5, 2002 | 04:15 AM
cournal's Avatar
what the hell did you do man.........
Old Aug 5, 2002 | 04:38 AM
Lunar7's Avatar
You should replace those hoses with some Viton tubing.
You can also make new pills yourself.
You can PM me if you want details on how to do this.
Old Aug 5, 2002 | 04:46 AM
JonesersRX7's Avatar
Lunar, I think a couple of people on here would be interested in how to make em'. In case I ever need to
Thanks!
-- Eric
Old Aug 5, 2002 | 05:00 AM
Rotormania's Avatar
I want the stock boost pills.
Old Aug 5, 2002 | 04:34 PM
JONSKI's Avatar
5yr member, joined 2001
IF your boost pills are in the rubber hoses, you can simply take them out and put them in your new hose. If you are adventurous, then try Rob Robinette's manual boost controller.
Old Aug 5, 2002 | 07:15 PM
MazdaMike's Avatar
the boost pills are in the 2 vac hoses towards the passanger headlight by the turbos?
Old Aug 5, 2002 | 10:12 PM
legendr35's Avatar
one hose it connected from the precontrol actuator to the manifold (compressor) and the other is from the wastegate actuator to the manifold.
which are both right next to the primary turbine
Old Aug 5, 2002 | 10:34 PM
duboisr's Avatar
Use 6mm hose ,buna N from the auto parts store is good of course viton is better. the long hose has the pill with the small hole the short hose holds the pill with the larger hole, Garfinkle makes pills for his customers also . You will need a set of numbered drills.
Old Aug 6, 2002 | 07:47 PM
Lunar7's Avatar
Thanks!
-- Eric
You can make new pills out of 1/4" dia aluminum barstock cut to 3/8" lengths.
Then drill a hole through the middle using numbered machinist drill bits.
Get a chart to convert the drill numbers to diameter in inches.
An indexing plate from your local hardware store will show you the conversion from drill numbers to inches and help you keep track of your numbered drill bits.
If you have access to a lathe, the pills will turn out great.
A drill press will also do the job as well if you are careful.
The pills you make yourself are actually better than stock since they cannot rotate in the line as the stock pills can.
BTW: Stock Pill sizes are:
Wastegate - 0.064in (Drill # 52)
Precontrol - 0.059in (Drill # 53)
Old Aug 6, 2002 | 09:09 PM
aReX-7's Avatar
You are right, since they are longer than stock pills, they won't turn in the hose. But the stock size hole in a longer peice of metal will increase air resistance through the pill and result in higher boost and prespool. Think about blowing through a straw that is 3 inches long, or 3 feet long. The longer straw has more air resistance!
Just something to think about.
Jeff
Old Aug 6, 2002 | 10:51 PM
johnchabin's Avatar
Use Holley carb jets. They work great.
Old Aug 6, 2002 | 11:59 PM
duboisr's Avatar
The length does make a differance ,Garfinkle makes them longer an factors in the length difference,
Old Aug 7, 2002 | 01:07 AM
Lunar7's Avatar
Jeff
Agreed,
Hole sizes should be determined by the boost levels you get in your car.
Stock size holes may not be correct for your car (w/ x mods & x length pill).
Most people will run larger hole sizes than stock to bring boost back to safe levels after adding mods.
Old Aug 7, 2002 | 08:48 AM
Just get two garden hose type little valves that you can buy at any home depot and install them in the lines with hose clamps and vary your pill size ..ie.. boost controller !!
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
