how do you take off the rear lower lip?!
Old Aug 4, 2002 | 09:50 PM
Qball's Avatar
Comp Yellow Mica
Question how do you take off the rear lower lip?!
this one bolt is pissing me off. its the one on the corners of lip the holding it.
i cant take it off. i cant unscrew it. it seems to be welded to the bracket. i cant bend it out of the way. it almost seems like i have to take off the bumper to remove it.
all the other screws are out except this one.. geeez. pissing me off =)
my rear lip was damaged recently and i have a replacement .. its driving me nuts.
here's a pic of what i'm talking about.
Old Aug 4, 2002 | 10:00 PM
Rotarius's Avatar
I took the rear lip too, i like it much better without it. If you want to buy it just PM me. About that bolt, it should have a nut behind; it use a small mirror (your girl`s compact) to see it. If someone put it in there, you sould be able to take it out. Its only a Japanese car not an advance alien race UFO.
Ev
Old Aug 4, 2002 | 10:11 PM
Qball's Avatar
Comp Yellow Mica
there's no tiny bolt. the screw is just stuck to the bracket. it seems to be one piece. i tried prying it off with a screw driver.
i have a replacement piece. so no need to buy one.. thanks for the offer tho.
Old Aug 4, 2002 | 10:16 PM
7Sweety's Avatar
Damn it man. Bust a nut, are you a cat or a mouse? J/K
Do it the AMERICAN WAY, by force, lots and lots of force.
Good Luck
Old Aug 4, 2002 | 10:18 PM
jpandes's Avatar
Use a dremel(the wonder tool) to cut it off...
Old Aug 4, 2002 | 10:20 PM
Rotarius's Avatar
I hate when a simple task turns into a @#%!nightmare!! Did you check with a mirror for a small n-u-t ? if that doesnt help, try meditation and prayer...
Old Aug 4, 2002 | 10:21 PM
Qball's Avatar
Comp Yellow Mica
i'm about too..... errrrrrrr
Old Aug 4, 2002 | 10:36 PM
Qball's Avatar
Comp Yellow Mica
no need for a mirror... i can see the front the back.. all angles of that piece. i can even pry enough of it to see inbetween and there's nothing there.
if all else fails.. i'm just gonna dremmel the end of the screw.
what's even more annoying. the bracket is metal and the screw is plastic. i was thinking its one of those push-lock screws because the head of the screw is smooth. but after pushing like hell against it. it still wont move backwards.
Old Aug 4, 2002 | 10:40 PM
Rotarius's Avatar
You might be right, the more you push back the more it digs itself into the plastic. Mine wasnt that hard, I guess someone dealed with it in the past.
One word.... Dremel.
Old Aug 4, 2002 | 10:44 PM
Qball's Avatar
Comp Yellow Mica
haha.. yeah.. i'm charging up my cordless dremel right now.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
MILOS7
Aug 15, 2015 09:40 PM
