What's wrong with my car?
Old Aug 4, 2002 | 09:10 PM
JackoliciousLegs's Avatar
haiO
Question What's wrong with my car?
My friend's auto gen 3 rx started sputtering as he pulled into his parking spot this morning. He shut if off, forgot about it, came back after work, and it refused to start and run. It turned over just fine, but it refused to run. He poured tranny fluid in to get it started and running, but when put in Drive or Reverse, the engine would just die. What does this sound like?
btw, I'm Jack, I have a first gen RX and am normally in that forum
Thanks a lot in advance for your input,
JackO
Old Aug 4, 2002 | 09:15 PM
Rotarius's Avatar
Did it ran out gas?
Old Aug 4, 2002 | 09:20 PM
I had the same problem... sounds like your apex seals are worn out .... but before you flip out , check your MAP sensor. You might change your plugs, and reset the ECU. If all fails , get the compression checked.
haiO
nope, has a full tank...
Old Aug 4, 2002 | 09:21 PM
haiO
I was hoping you wouldn't say that
Old Aug 4, 2002 | 09:25 PM
Rotarius's Avatar
Obious things first..... I would not recomend pouring AT fluid in a 3 gen, it may work for a carb car not a state of the art twin turbo, anyways; How old is the fuel filter? Pettit recomends changing it very often
Old Aug 4, 2002 | 09:28 PM
haiO
Where's the map sensor located?
Old Aug 4, 2002 | 09:29 PM
haiO
fuel filter is new
Old Aug 4, 2002 | 09:34 PM
Rotarius's Avatar
Has the check engine light turn on at all?
Old Aug 4, 2002 | 10:29 PM
haiO
Yes, the check engine light is on...
Old Aug 4, 2002 | 10:35 PM
Rotarius's Avatar
Start by retrieving the code from the ECU. It may pinpoint your trouble.
Old Aug 4, 2002 | 10:36 PM
haiO
wher'es the MAP sensor??? thanks for your help!!!
haiO
do you have a phone number i can call you on??? or AIM screen name??? my friend's from tallahassee.
Old Aug 4, 2002 | 10:40 PM
haiO
call me please on my cell, err... call my friend... we're together at the "crash site" 703-282-1123... call him and he'll call right back... his name's dustin, and mine's jack again... thanks
Old Aug 4, 2002 | 10:50 PM
Rotarius's Avatar
I have a dial up connection, and the MAP sensor is a little black box on the firewall next to the brake fluid/brake booster. Cant miss it it says boost sensor on top. It is possible that it could have become disconnected when he was driving but I doubt is that.
highspeedrider
Sep 8, 2015 07:55 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
