non-underdrive dual pully?
Old Jul 31, 2002 | 09:36 PM
I wish I was driving!
You could move the alternator to the a/c position and forget about needing a second belt. That's what I did, but it was necessitated by a very unique mod.
Just a thought, not very pracitcal, I know...
Old Jul 31, 2002 | 10:21 PM
FC Drifter's Avatar
Damaged Little F*cker
get a 3rd gen alternator if your worried about your stuff overpowering the alt. youd still need the dual sheave pulley tho
Old Aug 1, 2002 | 05:08 AM
banzaitoyota's Avatar
What Subscription?
extemeGTu: you have a PM
Old Aug 1, 2002 | 10:23 AM
wpgrexx's Avatar
does a 3rd gen alternator fit directly int an 86 gxl? i can't keep the volts up at 13 for the life of me. i have gone through 5 alternators in 4 summers of driving.
Old Aug 1, 2002 | 10:49 AM
other choice, is to put another belt ,,,from the crank pulley straight to the water pump,,, i can get that belt if you cant find it,,,hope thius helkps
Old Aug 1, 2002 | 09:24 PM
It bolts on, and takes two wires to solder to get it to work. The pulley must also be bored out to fit onto the larger FD alternator shaft.
You DEFINITELY do not want a underdrive pulley, as I'm sure you're aware.
As well, the second belt is really more to prevent slippage of the water pump pulley than the alternator.
Old Aug 1, 2002 | 09:26 PM
This what you're thinking of?
https://www.rx7club.com/forum/showth...ghlight=yoohoo
James Knox
Oct 22, 2015 05:08 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
