Vac Hose Diagram Need checked
Old Jul 30, 2002 | 05:14 PM
Conv.WS6's Avatar
I currently have the simplified Non Sequential vac hose diagram setup with the poor man's mod for non sequential. I want to get rid of the rest of the solenoids, and the following diagram is what I'm planning on doing. does anyone know if I'm deleting a needed vac hose that should not be? Thanks
Old Jul 30, 2002 | 07:48 PM
jr's Avatar
jr
Your missing the fuel pressure regulator solenoid.
Old Jul 30, 2002 | 09:08 PM
JONSKI's Avatar
5yr member, joined 2001
So is the simplification on Rob Robinette's site. Poor Mindphrame forgot it in his simplification, but he was sure to pass on the knowledge to me so I didn't make the mistake.
Old Jul 30, 2002 | 10:16 PM
Conv.WS6's Avatar
Thanks, I probably would have caught that when i started pulling and pluging all the solenoids. anything else? I appreciate the response that way I deffinitely remember that one.
Old Jul 18, 2003 | 07:52 AM
dubulup's Avatar
development
holy resurrected threads batman!
you don't need it. attach the line for the FPR straight to the LIM.
Old Jan 17, 2004 | 01:23 AM
Fatman0203's Avatar
Where is the fuel pressure selenoid Im lost cant find.
What happens if you dont attach it?
Old Jan 17, 2004 | 01:39 AM
Fatman0203's Avatar
OK found it.
Whats the worst that can happen if you dont attach it?
What "normally happens?
Old Jan 17, 2004 | 06:51 AM
clayne's Avatar
PV = nRT
Difficulty with warm starts. That's it.
It's called the PRC solenoid for Pressure Regulator Control. I removed mine. I use only 2 solenoids - wastegate and evap purge.
Old Jan 17, 2004 | 11:44 AM
Fatman0203's Avatar
Aye , ok, but you wont blow the engine or anything right?
Old Jan 17, 2004 | 01:28 PM
clayne's Avatar
PV = nRT
No.
Old Jan 17, 2004 | 01:30 PM
Fatman0203's Avatar
w00t ok thanks =p
That was a close one.
Old Jan 17, 2004 | 01:31 PM
WONG FRIED RICE's Avatar
R.I.P. GuitarJunkie28
so is this all u would need to do for a non-sequential setup?
Old Jan 17, 2004 | 01:36 PM
Fatman0203's Avatar
A boost controller would be nice.
Old Jan 17, 2004 | 01:37 PM
so all that was discussed and a boost controller?
Old Jan 17, 2004 | 01:39 PM
Fatman0203's Avatar
Check the archives for Rikki's Diagram, its the cheapest way to do it. I may do it in a bit, lots of people have done it with and are happy. Lag is dependent on your exhaust. FULL boost at around 3500 to 4000 RPM depending on your exhaust. Port and full exhaust would bring this down to 3000 probably.
Old Jan 17, 2004 | 04:39 PM
JONSKI's Avatar
OK found it.
That depends.
If you *bypass* the FPR solenoid (It's solenoid (A) in the diagram, orange plug, closest to firewall), then nothing will happen. You may find that it will improve your warm starts, because you won't be running nearly as rich.
If you leave your FPR vacuum line disconnected, then you will run very rich during idle and lean during boost.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
whinin
Sep 5, 2015 11:52 PM
rotor_veux
Sep 3, 2015 07:10 PM
