msd blaster 2 coil for stock ignition???
Old Jul 30, 2002 | 08:51 AM
DoceA's Avatar
Question msd blaster 2 coil for stock ignition???
OK,, I want to change my stock coils (I think they have never been changed on the car)... I was thinking of changing both leading and trailing to msd blaster 2's... In the future I would like to get an msd 6A ignition..... These are my questions:
1) Can I use 2 msd blaster 2's to replace the 2 stock coils even though I still have the stock distributor???
2) Can I use the 2 msd blaster 2's for the msd 6A ignition I plan to get in the future???
Thanks.
Old Jul 30, 2002 | 09:26 AM
RotorMotorDriver's Avatar
Seven Is Coming
Yes to both. Depending on which car you have (points or electronic ignition) you will either need the MSD's with or without the resistors. The points systems needs the resistors, and the elevtronic does not.
~T.J.
Old Jul 30, 2002 | 09:27 AM
Seven Is Coming
Oh, and I've heard that you cant mount the MSDs on their sides cause they are oil filled, so you may want to look into alternative mounting locations...The Drivers side strut tower seems to be a popular choice, especially with direct fire.
~T.J.
Old Jul 30, 2002 | 09:30 AM
DoceA's Avatar
thanks,, i luv the quick replies i get at this forum...
Old Jul 30, 2002 | 09:58 AM
DoceA's Avatar
which one will fit the wires on an rx7??? the chrome or red one,,, or are they the same... from pics,, i think the chrome msd blaster 2 coil has the head a little thicker then the red one.... the red one looks like it has a thinner head??..??..??
Old Jul 30, 2002 | 02:12 PM
DoceA's Avatar
difference between chrome and red,, anyone???
Old Jul 30, 2002 | 02:24 PM
treceb's Avatar
post *****. how ya like them quick responses now...
Old Jul 30, 2002 | 03:41 PM
David88vert's Avatar
r71's daddy
Use the High Vibrations - same as Blaster 2's but can mounted in any position.
Old Jul 30, 2002 | 03:49 PM
REVHED's Avatar
Hunting Skylines
~T.J.
I've had the Blasters in the stock location for years now without a problem as have many others. Besides, the stock coils are oil filled as well so I doubt it's going to cause any problems.
Old Jul 31, 2002 | 03:22 AM
Seven Is Coming
Ya learn something new everyday...Like I said, I had only "heard" that .
~T.J.
Old Jul 31, 2002 | 07:39 AM
inittab's Avatar
I read your email
I'm sure my coils are the stock 17yr old ones as well. Should I consider changing them? Do they weaken over time? TIA
Old Jul 31, 2002 | 07:49 AM
chuck8313BTSDS's Avatar
I converted my 83 rx7 leading side to a waste spark coil from a 88 rx7. Run the wires strait from the coil to the plugs. Seems to work fine so far. I left the trailing stock.
Old Jul 31, 2002 | 08:33 AM
DoceA's Avatar
~T.J.
Yeah,,, I heard summit recommends it... A couple of other people have told me that,,, and I read it in another post in the forum... I was thinking of buying the cadium bracket that says msd on it to mount it vertically.... Anybody else have or heard of people using the high vibration msd coil to use with the stock distributor???? Can it be mounted on its side???? Oh,, and does anyone know if the heads are different on the chrome and red blaster 2's???
Old Jul 31, 2002 | 08:09 PM
Seven Is Coming
Why would they be? They are designed to take a "typical" spark plug boot. Why would they make one different from the other?
~T.J.
PS - To me, that would be kinda like a spark plug company changing the diameter of a plug so that a wire doesnt fit anymore...It just wouldnt be smart
Old Jul 31, 2002 | 08:15 PM
Jaye's Avatar
Mounting location
I believe all universal coils, such as the MSD Blaster 2's, are oil filled.
MoTeC
Sep 10, 2015 07:58 PM
freq
Aug 21, 2015 03:30 PM
