How hard is it to install a header?
Old Jul 30, 2002 | 01:08 AM
redrx's Avatar
so i finally ordered the full exhaust for my car from mazdatrix (funny, racing beat was out of stock), but i was just wondering how hard it is to install, i wouldnt think it wouldnt be that hard, but sometimes you never know-
Old Jul 30, 2002 | 02:05 AM
yayarx7's Avatar
Are you Nucking Futs?
It is a straight forward affair unless you have the thermal reactor, then the bolts are kinda a pain to get to. Just unbolt, and bolt back up. With the full exhaust the thing should be a snap, with plenty of help here if you run into a snag. Good luck,
PS hello everybody !
Old Jul 30, 2002 | 08:14 AM
Directfreak's Avatar
I am a Jeeper Now.
What the hell are you doing in Saudi?
Old Jul 30, 2002 | 09:28 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
installing the header takes like 5 minutes, its taking all the old **** off that takes a long time.
Old Jul 30, 2002 | 09:48 AM
RotorMotorDriver's Avatar
Seven Is Coming
I'll second that. It took me forever to get my old **** off, with all the heat shields and **** on there. After it all came off, the new stuff slapped right on. Gasket, header, bolts, nuts, tighten, torque, all done . Then the pre-silencer, gasket, nuts, tighten, torque, all done. then the connecting pipe, gasket, nuts, tighten, torque. I think you get the picture .
~T.J.
Old Jul 30, 2002 | 09:59 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
I third that... Getting the old stuff off is a serious PITA! (PB Blaster is your best friend, soak it like a day in advance)
The new stuff goes on in about 20 min... just bolt it all up and tighten the crap out of it.
Old Jul 30, 2002 | 08:54 PM
the only difficult actually installing the system was with hanging the center SP section, that thing must weigh like 90 lbs.
Old Jul 30, 2002 | 10:57 PM
someone82's Avatar
I second that with the SP setup and the upper bolts on the first flange closest to the tranny are a pain.
I found for taking off the thermo-what-so-call-it-thingy just use a 3/8 uni. and thin wall sockets and a good 2 ft long ext.
Matt
Old Jul 31, 2002 | 03:01 AM
Seven Is Coming
Paul, is that the stock 86 alternator? Basically I need a double sheeve pully for my 12A alt. and i was wondering how you solved that problem. Also, hows that fan work for you? Its the same one that was in my car when i bought it, but since the engine was toast, i have yet to use the fan.
~T.J.
Old Jul 31, 2002 | 11:16 AM
Rotary-MG's Avatar
the name is Stan
Once the reactor is off, a sawzaw will go through the pipes in less than 30 seconds.
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
