Help Please!!! S5 T2????
Old Jul 28, 2002 | 11:27 PM
gz91rx7's Avatar
Ok I am trying to get my car up to 13psi and right now I can only get to 10psi! I was told that by removing the air pump and air control valve that would allow me to get more boost! Is that a true statement or a myth?
I have a boost controller as you will see when I post my mods but even if I turn it up to a full bar I dont get any higher than 10psi!
PLEASE HELP ME!!!! I am trying to get everything tuned right so that I can perform like I should at the track!
Here is my mod list:
Engine Mods:
- Trust Airnix Filter
- Greddy Extreme 60mm Exhaust
- Custom 3" Turbo Inlet
- Disabled secondary throttle plates
- 3" Hi-Flo Dynomax Catalytic Converter
- 3" Racing Beat Downpipe
- Hybrid Turbo Garrett T04B (Compressor) / Hitachi HT18 w/ ported wastegate
- Apexi dual chambered BOV
- Mild Street Port (intake and exhaust)
- Rebuilt block w/ FD corner seals and springs (4-5K miles)
- Racing Beat Engine Brace
- Magnacore 8.5mm Wires
- MSD 6A Ignition Pack (Leading Coils)
- HKS FCD
- Dual Pulley (Alternator)
- Apexi ACV-R Boost Controller
- Removed cat
Suspension Mods:
- Suspension Techniques Front Sway Bar
- Tokiko Illumina Shocks
- Trust Upper Strut Tower Brace
- (4) 17x8 (40mm offset) Rota Stage 5 Rims
- Dayton ZR Tires
- 215-45 (front)
- 245-45 (rear)
Transmission Mods:
- C's Short Shifter
- Mazda Trix Competition Mounts (new)
- Racing Beat Lighten Steel Flywheel (new)
- OS Giken Clutch (FD Stock Clutch) (new)
- ACT Heavy Duty Pressure Plate (new)
- Redline Oil in Tranny
- SS Braided Hydraulic Clutch Line
Fuel Supplement:
- FD Fuel Pump
- (2) 720cc Injectors in Secondary
- Apexi Super AFC
Thanks everyone!!!
Old Jul 28, 2002 | 11:33 PM
knight1976's Avatar
Please dont kill that beautiful *** car as soon as you get it................
Old Jul 28, 2002 | 11:40 PM
gz91rx7's Avatar
1. How did you know that I just got it?
2. It isnt a car that gets driven hard when it is on the street. I just want to know that I can turn up the boost when I need it!
3. I have my integra that is my daily driver so the 7 gets a much attention as it needs!!
Old Jul 29, 2002 | 12:00 AM
gz91rx7's Avatar
Ok there are alot of people in this forum and my post just keeps going down wtf???
Please help me out!!
Old Jul 29, 2002 | 12:15 AM
NZConvertible's Avatar
I'm a boost creep...
Not just a myth, a complete load of BS!
With all those mods, that’s a real surprise. Is that verified on another gauge, or is that what the boost controller says?
Do you mean dual 60mm? If so, you should’ve gone 2.5” (64mm) each side, it makes quite a difference, especially with a turbo like that. If that’s a single, that’s probably why you have no boost, that’s tiny!
Old Jul 29, 2002 | 01:08 AM
dr.jones63's Avatar
It's a Hammer
? where does your ACV-R go through the firewall?
Old Jul 29, 2002 | 04:19 PM
gz91rx7's Avatar
I have the greddy power extreme cat back(duals).
My autometer boost gauge only shows 10 psi even with my apexi avc-r at a full bar! wtf???
Old Jul 29, 2002 | 05:00 PM
gz91rx7's Avatar
hmmmm...........
Old Jul 29, 2002 | 07:09 PM
Cheers!'s Avatar
Former Rx7 *****
damn that is a sweet car.
Old Jul 29, 2002 | 07:35 PM
I wish I was driving!
hmmmm...........
Autometer boost gauges are notorious for reading low.
Old Jul 29, 2002 | 11:10 PM
gz91rx7's Avatar
Are you serious?!!?!!? Is there any other way to check my boost levels???
Old Jul 29, 2002 | 11:20 PM
yeah, get another gauge, like a compression tester.
Old Jul 29, 2002 | 11:24 PM
gz91rx7's Avatar
I will have to do that!!! Thanks for the info! Hopefuly everything turns out ok!!!!
Old Jul 29, 2002 | 11:47 PM
vosko's Avatar
Just Call Me Terminator!
your avc-r can read boost BUT i would check to make sure its hooked up correctly remember the S5 T2 has a boost solenoid make sure its not hooked up still. the avc-r can be a pain to setup correctly
Old Jul 30, 2002 | 01:04 AM
gz91rx7's Avatar
An aftermarket turbo doesnt have a boost solenoid does it?
Old Jul 30, 2002 | 02:25 AM
The solenoid isn't on the turbo itself, it's under the intercooler. On the stock turbo there's a tee in the wastegate actuator line that goes to the solenoid. With a turbo upgrade like yours and/or an EBC, this system isn't necessary. You should just have two hoses (one from the wastegate actuator and one from the compressor outlet) that go to two ports on the EBC's solenoid. Check all that plumbing is correct.
Sorry for not replying to your PM, but I'm a bit stumped on this one. You seem to have a ll the right hardware and shouldn't have any probs exceeding 10psi.
Hope it's just the gauge!
Old Jul 30, 2002 | 05:44 AM
importboi22's Avatar
Hks Ownz Me (
does your boost hold steady? cuz even with the wastegate unplugged on my car i could only get 10psi... only weird thing is the needle would jump like crazy between 8-10psi.... even on the hks AND apexi guage... found out that low compression was the factor whats your vaccum at idle? mines 12-14 which is another factor of low compression.
Old Jul 30, 2002 | 12:16 PM
gz91rx7's Avatar
Thanks for the post! I dont remember off hand but I think at idle my vaccum is near 20. Also about my wastegate at low speeds when I left off the gas it sounds like I have an exhuast leak!! Could this just be the wastegate? I dont believe that I have an exhaust leak!! I am going to check my vaccum at idle and post again!
Old Jul 30, 2002 | 05:47 PM
Hks Ownz Me (
with 20psi vaccum at idle i would think that you would be fine. check your turbo for shaft play. and doesnt the avcr able to read boost too what is it reading?
Old Jul 30, 2002 | 08:26 PM
gz91rx7's Avatar
it is the old avc-r It only shows % and bar.
I got a guy at the local import dealer that is the man with 7's but he isnt used to working on one with alot of mods. I am going to talk to him tomorrow!
Old Sep 5, 2002 | 10:40 PM
dr.jones63's Avatar
It's a Hammer
I installed an Auto meter boost gauge and a acvr. The stock gauge and the ACV-R show boost(.8 + on the ACV-R)(boost cut defence installed for stock gauge) but the autometer shows 1-0 psi. I dont know if theres a trick to hooking up the autometer or what but right now I think its ****. I changed out the brass ferrels on the tefflon line to the autometer and it didnt do any good.
Old Sep 6, 2002 | 01:30 AM
gz91rx7's Avatar
Well I thought that I had it all figured out but..........
I dont!
I have about 16 psi at idle which is pretty good.
I only hit 8 psi in 2nd and 9 psi in 3rd.
I thought that it was the duty cycle on my avcr but that doesnt seem to be it.
I am going to check my bov and see if it is maybe leaking after 8 psi.
I am going to check my lines to the gauge and maybe one is pinched alittle.
I will say one thing it really sucks that I cant boost any higher because I would love to be able to run 10 psi in 2nd and 3rd.
And if I wanted to bump it up more for that occasional kill.
If anyone has any info on my set up please let me know
Thanks,
Josh
Old Sep 6, 2002 | 01:33 AM
gz91rx7's Avatar
Oh yeah I was looking at my avcr while I was driving tonight and when I was hitting max boost the avcr was showing that my turbo was only at 83%. Soooooo I now need to figure out what that is all about. Hopefully that info will help get a answer to my damn problems.
Josh
Old Sep 6, 2002 | 01:43 AM
Scott 89t2's Avatar
SOLD THE RX-7!
as posted before... ditch the avcr and buy a ball and spring manual one for like $30 off ebay. if you can't get more boost with that. atleast then you know it's not the controller. if you do, then just keep it...
Old Sep 7, 2002 | 02:23 AM
dr.jones63's Avatar
It's a Hammer
Whats your solinoid duty set at?
