Newbie, needs help
Old Jul 27, 2002 | 11:45 PM
Newbie, needs help
Just picked up a 93 touring, has a blown tranny, My problem is as im pulling off the tranny i cant seperate it from the engine, I can see the flywheel and half of the torque converter, but i cant seem to seperate it all the way
Am i missing a step>??
..Any suggestions would be great, thanks
Old Jul 27, 2002 | 11:47 PM
Wargasm's Avatar
Weird Cat Man
Is this on a 5 speed or an automatic? You mention "torque converter" implying that it's an auto... in which case, I have no clue... if it's a 5 speed, you need to release the pull-type clutch from the pressure plate first.
Brian
Old Jul 28, 2002 | 03:06 AM
jspecracer7's Avatar
1JZ powered
Brian
Brian,
Hey since I've got OS Giken clutch set that turns the pull type clutch into a push type clutch(so I have NO experience with pull type clutches)....How do you separate a pull type clutch from the PP?
Van
Microtech
30
Apr 23, 2016 06:37 PM
Moppet52
Feb 4, 2002 02:14 PM
Daw Tse
Nov 16, 2001 10:59 AM
