white smoke when decelerating
Old Jul 26, 2007 | 01:14 PM
Rotaryterror's Avatar
hows it going?i have a 85rx that i just got off my freind.theres a few issues with the car but the main one i need some help with is when i have it around 5 to 6k and leave it dwell then let off the gas 2 or 3 times alot of white smoke came out of the exhuast.ive had the car for a week not and its only did this 4 times at the most.it has a home made exhuast pipe and muffler on there.anyone no what it could be?
and ive been trying to find out if the 1985 gsl has a lsd.thanx
Old Jul 26, 2007 | 02:07 PM
Kentetsu's Avatar
Does the smoke smell like oil? Sounds like oil control rings, in which case you should run a search for Lucas Heavy Duty Oil Stabilizer...
Old Jul 26, 2007 | 02:09 PM
Landon303's Avatar
the motor is getting old, and the oil control rings are loosing their ability to with hold oil from being burned, there for letting more get past the rings & be burned, thus the smoke.since it was up so high in the rpms, it got hot, and the rings expanded, and let that oil past. Nothing to worry about, if anything you're getting more lubrication. Just check the oil level at every fill up since it is now burning a little more than it would stock. All gsl's have lsd from the factory, unless someone switched it out. does it have rear disc? then chances are you still have your lsd
Old Jul 26, 2007 | 02:11 PM
Bptznumba1playa06@sbcglobal.ne's Avatar
Who wants to be pisst' on
if ist a gsl se it has lsd.for the gsl it was an option, but if you have rear disc brakes then you also have lsd.
Old Jul 26, 2007 | 03:41 PM
VintageMazda's Avatar
smoke on decel means the oil rings are going ...... going .......
Old Jul 26, 2007 | 03:46 PM
dbragg's Avatar
Say hello to Mr.Wankel
if its an INSANE amount of smoke it could be oil in the exhaust pipe. i did the ATF treatment to my first rx7. there was a build up of oil in teh exhaust. whenever the car would back fire itd send out a smoke screen.
Old Jul 26, 2007 | 05:13 PM
Kentetsu's Avatar
Make sure the oil level is not too high. That will also cause this... Otherwise, like I said, check out Lucas.
Old Jul 27, 2007 | 11:40 AM
thanx everyone for the help ill look into it
antman0408
Oct 5, 2015 04:33 PM
SpaceCadet_Alt3
Oct 1, 2015 11:35 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
