Machining rotors for high revs and oil pressure
Old Sep 4, 2006 | 03:21 PM
BuckyFD3's Avatar
GT4088R
I'm looking at machining some 8.5:1 rotors for my engine so i can rev it a bit higher safely without them hitting the side plates. How much do you machine off the 2 faces???
Also I have E shaft oil jet mods done and my oil pressure is just over 4kg/cm when driving around, is this oil pressure high enough to support the bearings??
I'm running big HB port and a T04R.
Old Sep 4, 2006 | 04:34 PM
RXBeetle's Avatar
Old rx7 competition manual says .13-.17mm clearance for a 9000rpm 12A pp motor. Hope that helps.
http://www.wankelkim.net/rx7/comp.manual.pdf
PS 4kg/cm is about 57psi for us here on on the other side of the pond.
Old Sep 4, 2006 | 06:31 PM
BuckyFD3's Avatar
GT4088R
Cheers looking through it now.
Old Sep 5, 2006 | 01:58 PM
BuckyFD3's Avatar
GT4088R
anyone??
Old Sep 27, 2006 | 09:19 PM
Dom_C's Avatar
So you would machine .005 off the whole face of the rotor? Hmm I might have to look into that.
Old Sep 28, 2006 | 03:18 PM
BuckyFD3's Avatar
GT4088R
I machined off 10thou of each face. You can take 12thou off but i didnt think i needed it as I dont want to rev OVER 9K.
Old Oct 1, 2006 | 05:41 AM
From doing a Bit of Reading be carfull not to go too much, There is quite alot out there about Side seals comping out of Place at high RPM. I admit i'm not sure how much was removed though but best not to guess.
Old Oct 3, 2006 | 08:05 AM
stevenoz's Avatar
You take about .0025 or .003 off each side of the face of the rotor. It won't hit the whole rotor....just the rotor landing.
Old Oct 3, 2006 | 02:39 PM
BuckyFD3's Avatar
GT4088R
I see what your saying but when you get your finger inside the port and feel the side seal, I can see how it can come out that far.
There isn't much seal exposed once the engine is bolted together.
andyvideopro
Aug 20, 2015 10:55 AM
20B Forum
Aug 18, 2015 02:46 PM
