turbo oil/water feed line help.
Old Apr 15, 2006 | 07:50 PM
ProjectD's Avatar
I'm on a Boat!
turbo oil/water feed line help ***pix***
I already posted this in the single turbo section but i'm looking for help anywhere i can get it.
Ok guys here is my problem. I just received my garrett to4R turbo from rx7store.net and there is a problem with the turbo oil/water feed fittings.
I need to know exactly what size the fittings are from the turbo oil feed line and the ports on the turbo it goes to. They are both female connection. but i didn't receive the fitting(s) that go in between it.
They also gave me the banjo bolt and fitting for the water feed/return line. but they are too small for the openig on the turbo. I need to know what size the wholes are on the turbo. I am quessing about a 16mm because i took the banjo bolt to autozone and they said it was a 14mm x 1.25 or 1.5(something like that.)
If anyone could tell me where i could find the banjo bolts and fittings for the things i need it would help a lot.
Thanx in advance,
Cyan
Old Apr 15, 2006 | 08:03 PM
ProjectD's Avatar
I'm on a Boat!
[IMG][/IMG]
[IMG][/IMG]
Old Apr 15, 2006 | 08:05 PM
ProjectD's Avatar
I'm on a Boat!
oops.. don't know why that second pic is so big lol
Old Apr 16, 2006 | 12:33 AM
SuIcIdeKiNg-'s Avatar
what turbo is it? Hey does OK for ur location stand for Oklahoma maybe even city??
Old Apr 16, 2006 | 12:35 AM
ProjectD's Avatar
I'm on a Boat!
It's a to4r. And yes i'm in Oklahoma. But i'm in the tulsa area.
The guy that did the porting on my motor is in OKC. you may know him, his name is Brad. He has a MB FD and a red FC
Old Apr 16, 2006 | 01:39 AM
ProjectD's Avatar
I'm on a Boat!
does anyone at least know where i can find these types of fittings?
Old Apr 16, 2006 | 08:34 AM
IRPerformance's Avatar
Sponsor
Hydralic shop. Bring the whole turbo there and they should be able to match something up.
Old Apr 16, 2006 | 09:02 AM
Mahjik's Avatar
Mr. Links
Looks like you just need a banjo (14mm or 16mm) to AN fitting. I got mine (not for turbo lines, but for oil cooler lines) from a local shop who sells Parker Fittings. You can go to Parker.com and look up a local shop that sells their fittings.
Old Apr 16, 2006 | 01:19 PM
ProjectD's Avatar
I'm on a Boat!
Sweet, thanx for the help guys.
Kyo
Aug 14, 2015 02:00 PM
