Drifting Discuss Drifting and drifting techniques here.
Steering knuckle mod "moar angle"
Old Oct 29, 2008 | 09:52 PM
  #101
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Yeah, you're gonna have to make them yourself. I would look into it but there doesn't seem to be much interest for the fd. Also from an engineering standpoint the cut weld spindles scare me. It puts the welds in shear rather than tension/compression like mine do. It appears people have had good luck with them though, we will have to see how mine hold up.
Old Oct 29, 2008 | 10:58 PM
  #102
J.T.P.'s Avatar
Hot Line
as long as it's cut/welded properly there shouldn't be a problem.. i've dirty dropped each front tire pretty hard at willow, slammed into tanner during tandem, and neither have broken.
i'm looking forward to trying yours out though, it's definitely an easier attempt at what seems to be the same thing.
Old Oct 30, 2008 | 09:42 PM
  #103
chwkrx7's Avatar
maybe this is a stupid question, but i'm trying to wrap my head around a few things here.
This would throw toe out and require a re-alignment wouldn't it?
I'm N/A, so i won't be doing any spindle modifying. I want to put spacers on my inner tie rods, so am I going to need a re-alignment afterwards? Something tells me this is a retarded question, but my brain is dead. Lol.
What i don't understand is how does this give you more angle? Wouldn't you just have to adjust the tie rods to compensate for the spacer, and then you're back to square one again? Someone please explain this?
Oh and btw I'm running 16x7 +16 wheels up front with a 205/45 tire
Old Oct 30, 2008 | 10:48 PM
  #104
The inner tie rods bottom out on the rack to stop movement. By adding the spacer you're moving the bump stop out and allowing more lateral rack movement. Yes you will need an alignment after and you may have to cut a couple threads off the inner tie rods.
Old Oct 31, 2008 | 12:18 AM
  #105
chwkrx7's Avatar
oh ok, that makes sense. thanks man!
Old Nov 3, 2008 | 04:39 AM
  #106
RussTII's Avatar
Veteran: Air Force
we can soon have S-chassis-like angle
Hrees the link from Zilvia.
or you can go to their official website
http://zilvia.net/f/advertiser-speci...-knuckles.html
Old Nov 3, 2008 | 06:38 PM
  #107
My modded spindle pics.
Stock
Modded
Stock
Modded
Stock
Modded
LCA Clearence
Sway Bar Clearence
Old Nov 3, 2008 | 08:02 PM
  #108
Oun's Avatar
Oun
I can confirm.
you would get more swaybar clearance by running lower offset wheels right?
Old Nov 3, 2008 | 08:13 PM
  #109
Yeah but I have 16x8 0 offset wheels now. The wheel is just barely touching the swaybar. I'll remove the swaybar and throw in the steering rack spacers I have and maybe add a slip on spacer for a couple extra degrees.
Old Nov 3, 2008 | 08:18 PM
  #110
Oun's Avatar
Oun
I can confirm.
wow that sounds beast. your gonna have to post pics when you get all that stuff put in too
Old Nov 3, 2008 | 11:51 PM
  #111
Wezzmo's Avatar
if you hit the swaybar one way, you'll hit the lca when you turn the other way..
i had 17x9 -7, and it hit the lca and swaybar badly
Old Nov 4, 2008 | 12:12 AM
  #112
dkwasherexd's Avatar
Garage Life
remember every 25mm is about one inch. t2 rotor has 16x8 0 offset, wezzmo has 17x9 -7 the extra inch is another 25mm wider making it hit the lca and swaybar easier. Minus the -7 offset. I would just find some 1" spacers and add abit of camber..
The wider wheels you run the more Neg. offset youll need to clear the lca and swaybar, especialy if you have mad steering angle. Then you will also have to take the front fenders into consideration to make the fitment and angle functional.
I wish the front LCA was longer.... Its pretty short..
Numbers numbers lol
Old Nov 4, 2008 | 03:12 PM
  #113
I have about an inch and a half of clearance between the tire and LCA. Sway bar is coming out asap.
Old Nov 5, 2008 | 12:58 AM
  #114
Wezzmo's Avatar
Numbers numbers lol
i found that if you go much wider than 17x9 -5 with 215/45s you start getting issues with the wheels hitting on the kit/guards, as it has such a wide scrub radius. (think thats right?)
really need 40 profile tyres..
Old Nov 5, 2008 | 01:16 AM
  #115
Garage Life
well, to give a close idea, this is my 215/35 on a 9.5wide .The smaller sidewall gives it more stretch, plenty of clearance from rubbing! can actualy have the rims come out of the body while the tires inside the fender. Running at 70psi, need alot of psi to hold air.Running stretch lets you have more NEg. offset=more angle. Im guna have this pair in the front when I find another wider pair of wheels for the back. Name:  P1020157.jpg
Im might try out t2 rotors spindle mod when If I can haz money..Il also need to get the mazdatrix angle kit to work with the t2 rotors mod am I correct?.. damn angle aintt cheap.. For now im just stuck at tierod spacers...
Old Nov 5, 2008 | 10:09 PM
  #116
chwkrx7's Avatar
^^ those must be a HUGE pita to get onto those wheels.
Old Nov 6, 2008 | 01:29 AM
  #117
Garage Life
Most shops use a cheetah....some backyard home garage guys use the starter fluid method..
Old Nov 6, 2008 | 01:13 PM
  #118
J.T.P.'s Avatar
Hot Line
cut a piece of hose, wrap it around the wheel in between the lip and bead of the tire, cut to size, the spray a little tire lube, and fill.. easy and safe.
on my ame wheels i had at sema last year, i had a 215/35/18 on a 10, suprisingly they didn't even need the hose method.
Old Nov 6, 2008 | 02:10 PM
  #119
Garage Life
damn i never knew about that method,its alot safer than cheeta and starter fluid method for sure, Ill have try it next time
Old Nov 6, 2008 | 09:19 PM
  #120
7syawedis's Avatar
the only wheels that ever gave me troubles were my rpf1s, i even went up to a 245 but it didnt help much. i filled in the gaps with tire lube goo, about 4 handfuls total and it sealed it enough to pop the bead. it makes a huge mess though when it pops it shoots everywhere, its pretty funny really. but most of it you can put back in the can and reuse.
anyway good work at least thinking of doing this with the fds. now i should actually read this thread and see whats going on.
Old Nov 7, 2008 | 05:23 PM
  #121
ballinnmiami240sx's Avatar
Here is what the stock knuckle on the FD looks like. I have a few ideas to make it better for more angle.
Old Nov 7, 2008 | 05:51 PM
  #122
1st option: the same as the FC mod.
2nd option: Welding a drop piece of metal to the spindle and drilling to hole thru it. One for super angle and the other slap YO mama max angle. It would also correct bumpsteer on hella dropped FD's.
3rd option: Drilling the spindle and re enforcing it with 1/4 plates on each side. May not work because of the drop angle the OEM mounting point is at.
Let me know what you guys think. I have an extra set of knuckles I want to mod.
Old Nov 7, 2008 | 06:09 PM
  #123
2nd option, the arm is on too much of an angle to properly gusset, and drilling a hole through the arm would significantly weaken it. I would have the stock tie rod hold drilled out to remove the taper and get an appropriate sized bolt and DOM tube. Put the bolt through the tie rod hole and put the tubing over the bolt and weld it all up to the arm. Get a 1/4in plate and drill it for the OD of the tubing and weld that and figure out something for the other side upright brace.
Old Nov 7, 2008 | 08:10 PM
  #124
This is what I was thinking on option#2
this would give you an option for how much angle and would correct bumpsteer.
Old Nov 8, 2008 | 02:51 PM
  #125
They look as though they have been machined out of a solid block. I say pick up some 1/2" .250 wall DOM and a hole saw to notch it and a tap.
