widebody from scratch
Old Oct 31, 2008 | 05:03 PM
  #51
Ro7aryInfect3d's Avatar
Just Touge It!
your work is looking pretty good, kepp it up
Old Oct 31, 2008 | 06:27 PM
  #52
dawicka2's Avatar
well rested,buffet o food
Hypertek: What i am gonna do is temporarily bolt them on by "boat resoning in" bolts on the back of the kit. I will use my existing mounting holes from the hemorrhoids to attatch them. They are going to require a lot of work (monday all day off and on) to get them to bolt and unbolt on. The reason for this is so i can paint them off the car and pop em back on. This is all temporary because i plan on repainting the car 2 tone, black above the door top/ a pillar line continuing around the car, and another color below that, covering the bulk of the car. Similar to yours, just none of the fender in the same color as the top.
Another reason i want them to bolt on and off is due to suspension. I have no idea what set up i will be running, and will need to cut the hell out of the rear quarters for top tire clearence. It will not be an issue with my stock setup. After inside is cut out (before new paint) i will then mold them to the car. Also cant mold them yet because i have the old erebuni wing on its way and i want everything to bolt on and off with ease and perfect fitment prior to moulding.
Thanks man, always helpful with the links.
**** now i forget the other question...
john ny
Old Oct 31, 2008 | 06:30 PM
  #53
dawicka2's Avatar
oh yeah......... miata engine bay. Not quite finished. Still need to find the edging that matches the image in my head, i promise i will post pictures as soon as it is worthy.
john ny
Old Nov 4, 2008 | 05:51 PM
  #54
dawicka2's Avatar
Kit fits now. It is able to bolt on and off with no effort. Ended up staying in maryland an extra day so didnt get to work on it yesterday. Bolts resined in the back of kit using old doodoo kits mounting holes. I wish it was 20 degrees warmer so i could friggin paint.
here are some horrible night shots....
Attached Thumbnails widebody from scratch-sebbysebsebs-009.jpg   widebody from scratch-sebbysebsebs-010.jpg   widebody from scratch-sebbysebsebs-011.jpg
Old Nov 5, 2008 | 01:36 AM
  #55
Hypertek's Avatar
Slowpoke
gonna be a scarry day to cut up some perfectly good rear panels that are painted... !!!
Old Nov 6, 2008 | 11:27 AM
  #56
dawicka2's Avatar
Yup it will be. I will post paint pictures if i can come up with some kind of bootleg paint booth situation. Put act clutch in this past weekend, its good to have the car going again. I might just drive it like it is with these two black growths for a while.
john ny
Old Nov 6, 2008 | 01:39 PM
  #57
classicauto's Avatar
Crash Auto?Fix Auto.
Originally Posted by dawicka2
If you are refering to my car i clearly stated they were 9 inch wheels out back
john ny
I've got 9.5" wide wheels out back under the stock quarter with no rolling, pulling or anything. Do I win a prize??
Old Nov 6, 2008 | 01:46 PM
  #58
dkwasherexd's Avatar
Garage Life
it depends on ur offset, and tire size.
Old Nov 6, 2008 | 02:00 PM
  #59
Viking War Hammer's Avatar
*** Bless The USA
This is what a local guy did. All in his Appartment Parking Lot.
Old Nov 6, 2008 | 02:17 PM
  #60
87 t-66's Avatar
not a drifter
a widebody NA? why?
Old Nov 6, 2008 | 03:24 PM
  #61
Mine are just Falken FK452's 255. The offest is +35
Old Nov 7, 2008 | 12:00 AM
  #62
dawicka2's Avatar
when i said they were 9 inch wide wheels out back, it was just to clearly state they were not "narrow *** wheels". In the context of "narrow assdum " they are wide, but not in the world of 2nd gen rx7s.
Do you get a prize for fitting 9.5 inch wheels out back? Nope.
Should you get a prize for putting your car together with all of that 1 off customness? Yes sir. **** is dope.
john ny
Old Nov 7, 2008 | 12:07 AM
  #63
Agent_D's Avatar
rawr
Originally Posted by 87 t-66
a widebody NA? why?
widebodies are only ok to use on turbo's?
Old Nov 7, 2008 | 02:29 AM
  #64
Hypertek's Avatar
Slowpoke
Viking War Hammer - wow he did a pretty good job, do u have a link? did he leave the foam underneath or did he use it to cast a mold for the fiberglass and remove the foam and place the fiberglass back up?
Old Nov 7, 2008 | 04:03 PM
  #65
dawicka2's Avatar
How much time is in that thing, viking? That actually looks really good. Is he a forum member?
john ny
Old Dec 13, 2008 | 05:14 PM
  #66
dawicka2's Avatar
Its been over a month.......Here are some updated pictures of the **** demon.
cut the hell out of rear quarters. This is an early picture right after rewelding seam and por 15. It is before final roll, picture another 3/4 of an inch of clearance. por15 is serious *****.
grandpa's HATE when you convert one of the storage areas in the basement to a paint booth
widebody mount
something is apparently wrong with the motor in my headlights....
trimmed wing to allow for widebody, tossed it up in the air and it landed on the car like this (simple 23 second test fit....too cold)
wing is not for everyone, i think it will look ok when fit and painted though.
I will try to get color and clear (sorry grandpa) on the wing tommorrow after hours of fitting.
John NY
Old Dec 13, 2008 | 05:24 PM
  #67
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Thread should be retitled "how to make rice" because at the end of the day you still have a 9" wheel in the rear.
Old Dec 13, 2008 | 05:42 PM
  #68
dawicka2's Avatar
^^^^9 inch wheels for now.......... Keep in mind shitty ****, that the car is a work in progress. Found a good deal on these rims 16x8 and 9, ultimately going to sell them for some 18x9 front and 18x11 or 12s in the rear. That is the plan after i two tone the car next year. These rims were great for the budget build (4200.00 total or so in car), but not where i am going to finish.
John ny
Old Dec 13, 2008 | 05:51 PM
  #69
Hypertek's Avatar
Slowpoke
should debadge trim the fenders to clean up the rear.
didnt realize you where 4 lug, your kinda stuck with teh advans til you go 5lug since theres not really many good 4 lug wheels
Old Dec 13, 2008 | 06:01 PM
  #70
dawicka2's Avatar
^^^^^^And shaving 3rd brake light....... I may have to upgrade to 5 lug at some point then. There are available 4 lug wheels though, like: http://cgi.ebay.com/ebaymotors/JDM-1...Q5fAccessories
john
Old Dec 13, 2008 | 07:28 PM
  #71
RussTII's Avatar
Veteran: Air Force
you could have fit that rim under the stock fender. I have a 10J +4 on the back and its tucked. Alot depends on your tire sizing as well. I think what you have on there is way too big. And I realize this is a work in progress but i personally believe you should buy your wheels first, then buy the reaer over fenders that create the best look, wether its 20/30/50 mm. Then all you need to do is MAYBE use one 5mm slip on spacer slip on spacer to fill any gaps left
Old Dec 13, 2008 | 08:29 PM
  #72
n20zuki's Avatar
im glad you decided to buy a widebody kit... the hemeroids looked like 2x4's stuck to the side of the car. Its a work in progress, lookin good so far.
Old Dec 13, 2008 | 09:15 PM
  #73
francogt1's Avatar
Lots of Hope
nice, hopefully i'll see it in person when its all done!
Old Dec 13, 2008 | 11:38 PM
  #74
dawicka2's Avatar
I agree with what you said. It makes a lot of sense. But on the car, rear kit-less just didnt look right. Front was all wide and agressive looking, with a crack headed rear end. Plans down the road will include fitting rims to the bodies specs and prob a 5 lug conversion. Did this to add symetry to the overall look of the car and stand behind it. For now that is its function.
n20zuki: Me too........looked even worse in person.
francogt1: Definately, man.
john ny
Old Dec 14, 2008 | 03:17 PM
  #75
dawicka2's Avatar
2 more. Badges off and front shot
john ny
