*** 1st Gen 1/4 Mile Leader Board ***
Old May 17, 2007 | 09:34 AM
  #51
blown7's Avatar
Double Ds for me to share
1) mannyvidal -----------------------10.89- @ 124 ------------------------------ ?? ???, 13B, Bridge
2) WAS:12A ------------------------- 11.45- @ 117------------------------------ 85 SA22C,13BT, Highflowed,
3) kuhlrx7 ---------------------------- 11.9-- @ 126 ------------------------------ 79 SA22C, 12AT, Street,
4) steve84GS TII ---------------------13.59- @ 106 ----------------------------- 84 GS, S4 13BT, S5 Turbo, Stock
5) estevan62274 ---------------------13.6-- @ 102 ----------------------------- 84 GSL-SE, S5 13BT, Stock
6) 84stock ---------------------------- 15.1-- @ ?? --------------------------------85 GSL-SE, 13B, Street, S/C
7) blown7 ----------------------------- 15.267 @ 89 ------------------------------ 85 GSL, 12A, 1/2 Bridge
8) aws140 ---------------------------- 15.2-- @ ?? -------------------------------82 GS, 12A, Stock
9) dean7 ------------------------------ 15.6-- @ 89 ------------------------------- 84 GSL-SE, 13B, Stock
10) IanS ------------------------------- 15.887 @ 86 ------------------------------ 83 GS, 12A, Street
11) Directfreak ----------------------- 15.9-- @ 89 ------------------------------- 85 GSL-SE, 13B, Stock
12) Chiron ---------------------------- 16.2-- @ 93 ------------------------------- 85 GS, 12A, Stock
13) cheddaj -------------------------- 16.8-- @ 89 ------------------------------- ?? ??, 12A, Stock
Old May 17, 2007 | 10:20 AM
  #52
drittens's Avatar
"2) WAS:12A ------------------------- 11.45- @ 117------------------------------ 85 SA22C,13BT, Highflowed, "
An 85 SA?
Old May 17, 2007 | 01:57 PM
  #53
Rx Seven's Avatar
Can You Wankel?
They never got the FB chassis code so all 1st Gens out side of the united states are reffered to as SA's and he is in Austarlia.
Old May 17, 2007 | 02:27 PM
  #54
dj55b's Avatar
Even though it was a really bad run but meh ... lets add it on. First time ever drag racing, slipping clutch, missed 3rd gear also.
Reaction --- 1.2988
60 ft -------- 2.4542
330ft ------- 6.9752
1/8 ET ----- 10.6950
1/4 ET ----- 16.4752
1/4 KPH --- 125.30
I'll be back to get my real time hopefully this summer
mods in sig
Old May 18, 2007 | 02:49 PM
  #55
blown7's Avatar
13) dj55b ----------------------------- 16.475 @ 77 ----------------------------- 84 GSL, 12A, Street
14) cheddaj -------------------------- 16.8-- @ 89 ------------------------------- ?? ??, 12A, Stock
Old May 18, 2007 | 07:26 PM
  #56
Max7's Avatar
Admitted Sevenaholic
14.942 @ 92.61MPH
GSL-SE - full interior, Stock 100k+ 13B block, working 6ports, Cone Filter, Full RB exhaust, MSD Direct Fire, 16" Eneki, Nitto 555R's
Old May 19, 2007 | 02:59 AM
  #57
dj55b's Avatar
to be honest ... I didn't think we woul ge this many replies ... if this could get stickied that would be awesome ... or just archived somewhere.
Old May 19, 2007 | 10:47 AM
  #58
blown7's Avatar
2) WAS:12A -------------------------- 11.45- @ 117------------------------------ 85 SA22C,13BT, Highflowed,
6) Max7 ------------------------------- 14.942 @ 92 ----------------------------- 85 GSL-SE, 13B, Stock
7) 84stock ---------------------------- 15.1-- @ ?? ------------------------------- 85 GSL-SE, 13B, Street, S/C
8) blown7 ----------------------------- 15.267 @ 89 ------------------------------ 85 GSL, 12A, 1/2 Bridge
9) aws140 ---------------------------- 15.2-- @ ?? ------------------------------- 82 GS, 12A, Stock
10) dean7 ---------------------------- 15.6-- @ 89 ------------------------------- 84 GSL-SE, 13B, Stock
11) IanS ------------------------------- 15.887 @ 86 ------------------------------ 83 GS, 12A, Street
12) Directfreak ----------------------- 15.9-- @ 89 ------------------------------- 85 GSL-SE, 13B, Stock
13) Chiron ---------------------------- 16.2-- @ 93 ------------------------------- 85 GS, 12A, Stock
14) dj55b ----------------------------- 16.475 @ 77 ----------------------------- 84 GSL, 12A, Street
15) cheddaj -------------------------- 16.8-- @ 89 ------------------------------- 84 GS, 12A, Stock
Old May 19, 2007 | 11:10 AM
  #59
chava_rx7's Avatar
Got mine runnin!!!! got to the track today!
Will have numbers down tomorrow!
Old May 19, 2007 | 05:40 PM
  #60
Directfreak's Avatar
I am a Jeeper Now.
SEE THE FIRST POST IN THE THREAD, AS I WILL CONTINUE UPDATING THAT ONE.
BEST E.T.
(ELAPSED TIME)
###.FORUM NAME:...... E.T...&..MPH.........CLASS...| YR | MODEL...| ENGINE | PORTING.... | MODS.......................
BEST M.P.H.. (MILE PER HOUR)
Old May 19, 2007 | 07:01 PM
  #61
blown7's Avatar
I've run a 15.421 @ 90.6 mph. Our 12a is topped with a weber 48IDA, backed with RB 4.44 gears in a SE diff.
Old May 19, 2007 | 08:19 PM
  #62
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
Hey Directfreak! Good job!! Looks great!! but my info is not correct
I have a S5 TII engine w/stock ports and S5 Turbo... runing S5 TII ECU, 8psi of boost
Mods are K&N, ported wg, 3" DP to 3" Borla mid pipe and magnaflow muffler.
Thank you Sir, Steve
Old May 19, 2007 | 10:58 PM
  #63
mannyvidal's Avatar
come get some.....
yea bro it looks great but my info is also wrong my car is a 1982 gs ford 9 inch , thanks in advance keep up the good work
Old May 20, 2007 | 01:02 PM
  #64
WAS:12A's Avatar
O.K. here's a few more details on my engine mods if you want to update them at all:
-13bt conversion.
-S5 housings
-S4 rotors
-S6 stationary gears
-2mm seals
-12at front cover
-S5 custom highflow turbo -specs 59mm front wheel with cropped rear on S5 manifold.
-Microtech LTX8 computer with coils and DASH unit inside the car.
-Custom EFI injection setup with hat and stainless steel piping
-880cc and 1700cc injectors
-PWR alloy oil cooler, intercooler, and radiator.
-Turbosmart type 2 BOV
-EBOOST with 3 boost settings set up on 10/14/18psi
-S4 turbo gearbox
-Custom brass button clutch and lightened flywheel
-Short shift kit
-Custom 3’’ mandrel bent exhaust, 3’’ highflow cat with one stainless steel magnaflow muffler and 4’’ dump.
-Running a 9 inch diff with 4.3 ratio LSD and 31 spline Billet axles.
Car has been dyno’d and made 318rwhp on 16.5psi
Has run a 11.45 @ 117.73mph on MTslicks with 1.52 60'er
Cheers
Cam...
Old May 20, 2007 | 03:26 PM
  #65
drittens's Avatar
Directfreak, geez, with that mph and et(12.440 @ 127.29), you must have been a ball of smoke all the way down the track! I've seen a GN pull a 10.9 at 123!
Old May 21, 2007 | 07:22 PM
  #66
|VEX|'s Avatar
Newbie
Hey can anyone help me out i like 1st gen rx7 but i dont know what year and what class of rx7 to look in to to start off with
Old May 21, 2007 | 11:08 PM
  #67
dj55b's Avatar
reading the first gen FAQ page will help alot with that answer ... if you plan on racing with it, picking a GSL model especially the 84-85 style since it has the beefier rear end and a few more things are available for that thanks to Billy at REspeed. Also good thing about those is that you get disk brakes all around. The GSL-SE is another one to look for. Although a bit more rare since it had the 13b engine which boost about 30hp extra ontop of the 12a, and having bigger brakes along with a better bolt pattern (4x114.3 as oppose to the weird pattern that most of the rest of us are stuck with 4x110 ... ya don't ask ) anyways this is just a very brief intro .. but reading the FAQ should be your next on the to do list before shooting any questions.
Old May 23, 2007 | 12:12 AM
  #68
Siraniko's Avatar
RX for fun
[/QUOTE]
14)Wackyracer-----------------------------------------14.2 -----------------RX-3 13-B streetport/48 IDA
@ CA Speedway. That was my last run with the socal crew. Could have been faster but I couldnt launch hard due to busted lug nuts in both rear tires (had to rig it to pass tech inspection). My time was posted @ west forum years ago but that thread has been deleted.
Old May 23, 2007 | 10:21 PM
  #69
kgray's Avatar
GOT WANKEL?
R/T .447
60' 2.457
1/8 10.90
MPH 64.75
1000' 14.17
1/4 16.69
MPH 80.3
Stockport 12A with magnaflow exhaust, spinning through first and part of second.
Old May 25, 2007 | 03:29 PM
  #70
Max7's Avatar
my MPH and mods were missed.
14.942 @ 92.61MPH
Old May 27, 2007 | 12:55 PM
  #71
peejay's Avatar
Old [Sch|F]ool
15.114 @ 90.49 - '80 RX-7, mild street ported 12A, stock carburetor, poorly modified intake manifold, Pacesetter header, MSD 6AL
Forgot what i did with my '85 (stock 12A), I remember I got a 15.7 out of it before I put a ported intake manifold on, or put the straight exhaust on, or put the gears in it... I stopped drag racing when I started rallycrossing.
Old May 28, 2007 | 09:57 PM
  #72
1sgen's Avatar
583 rwhp 1st gen
i know its 1/8 mile but this is all i got
60ft 2.016
330 5.343
1/8 7.985
mph 95.65
dot road racing miata slicks :-)
13brew with a 62.8mm turbo
full interior and even a spare tire
100% street car
Old May 30, 2007 | 08:59 AM
  #73
I am a Jeeper Now.
60ft 2.016
330 5.343
1/8 7.985
mph 95.65
100% street car
Nice times, but unfortunately I don't know where to put it.
At least the info is here in the thread until you get a chance to run
a full quarter.
Old Jun 15, 2007 | 08:54 PM
  #74
12akid's Avatar
r/t .687 60ft 2.418 trap 67.5 1/8 10.413 stock 12a headers no intake
Old Jun 17, 2007 | 06:32 AM
  #75
12at's Avatar
10.21 @ 137mph
Reaction time: 1.16
60 ft: 1.49
330 ft: 4.21
660 ft: 6.49
660 mph: 104.05
1000 ft: 8.50
ET: 10.21
MPH: 137.45
Mods: 12a bridgeport, TA45 turbocharger, 13bt intake, FMIC, microtech computer, T2 tranny and hilux diff.
