New turbo GT4094R
Old Oct 5, 2006 | 09:53 AM
Zero R's Avatar
Just in time to die
500R would be a better daily driver for sure
Old Oct 5, 2006 | 07:00 PM
So it's safe to say that (in general) this offers a 4500 rpm and up powerband, whereas the 500r offers a 3500 rpm and up powerband (on a 'normal' streetported engine)?
Old Oct 5, 2006 | 08:13 PM
Zero R's Avatar
Just in time to die
I would say yes in a overall view that is about what your looking at.
-S-
Old Oct 9, 2006 | 10:34 PM
  #29
No_Rotor_RX7's Avatar
how would you compare this to a greddy T78?
Old Oct 9, 2006 | 11:13 PM
  #30
Zero R's Avatar
Just in time to die
Better response, roughly the same power levels, could do better than some could do worse than others. It seems T78 dyno sheets vary greatly.
-S-
Old Oct 18, 2006 | 02:58 AM
  #31
brooklynfc3s's Avatar
what would your price on this turbo be?
Old Oct 18, 2006 | 06:01 PM
  #32
Zero R's Avatar
Just in time to die
PM sent
Old Oct 21, 2006 | 12:09 AM
  #33
sk8world's Avatar
Chasing numbers
Sean, Did you get my last 2 pm's!
Old Oct 21, 2006 | 01:12 AM
  #34
Indian's Avatar
It wasn't me!!
price?
Old Oct 23, 2006 | 10:15 AM
  #35
The Wankler's Avatar
FKITALL
This guy still owes me $150.00 bones, do not trust him.
Old Oct 23, 2006 | 10:27 AM
  #36
FD-Dave's Avatar
A price on this would be great.
Old Oct 31, 2006 | 02:57 PM
  #37
sk8world's Avatar
Chasing numbers
Sean, never heard back from you on my last PM.
Old Jan 13, 2007 | 10:50 AM
  #38
sk8world's Avatar
Chasing numbers
No one else want one of these?
Old Jan 27, 2007 | 09:41 PM
  #39
rico007's Avatar
La FIEBRE
Need price please for second gen
Old Mar 27, 2007 | 08:15 AM
  #40
sk8world's Avatar
Chasing numbers
Old Apr 25, 2007 | 12:59 AM
  #41
sk8world's Avatar
Chasing numbers
Any trick to getting this DP with dump to line up with wastgate? Seems about 1 inch too long? I have the DP installed to turbo but thats it. Just can not get the rest to line up. ????
Old Apr 25, 2007 | 02:05 PM
  #42
Zero R's Avatar
Just in time to die
????? Email sent.
-S-
Old May 4, 2007 | 01:08 AM
  #43
sk8world's Avatar
Chasing numbers
Sean, Have any maps for PFC with this turbo and streetport. Just checking. I thnk my 40r maps will be fine for a starting point.
Old May 4, 2007 | 10:02 AM
  #44
Zero R's Avatar
Just in time to die
Actually at the moment no, dont do too much PFC stuff so I haven't had a car that has had both this setup and that ECU here as of yet. You are correct that those maps you have will be good for a starting point just remember this will move more air than your last setup.
-S-
Old May 8, 2007 | 01:05 PM
  #45
sk8world's Avatar
Chasing numbers
Got the DP fitted in but it was a major hassle. Now I have exhaust leaks around the wastegate. The flex area of the DP is hitting the rear fire wall pretty hard. From the way I had to push and angle everything together I now have the MP touching the side under car. Can this cause a fire?
Sean, it really seems as the dump tube is 3/4 to 1 inch too long?? I have to say the last kit from you with the 40r kit was sooooo much easier to install.
Old May 9, 2007 | 08:37 AM
  #46
Zero R's Avatar
Just in time to die
Yes the newer kits are harder to install for sure the older ones were much easier by far.
-S-
Old May 15, 2007 | 10:48 PM
  #47
sk8world's Avatar
Chasing numbers
Sean, what spring rate came with the tial wastegate? 10psi? I still have not resolved the exhaust leak. Taking it to a shop next week to ahve them shorten the dump tube.
Old May 16, 2007 | 02:34 PM
  #48
Zero R's Avatar
Just in time to die
They all come with a 13psi spring. I never heard back form you on the DP so I assumed you got it to fit ok. Don't do anything with it I will get another DP made and sent out to you. We can also add the extra bung on there as well.
-S-
Old May 16, 2007 | 11:33 PM
  #49
sk8world's Avatar
Chasing numbers
-S-
No, never really got it to fit so I have a bad exhaust leak (think that may be the reason I am having high boost with just spring) I was actually going to take it down Friday to a shop but worried they would make my stuff look like **** so this would be great! I have a couple questions. If you are going to make me one is it possible to do a 4 inch then taper to 3in mp? Or is that a waste? How long on either? I have a tuning session set up for June 2-3ish. Thanks, Mike
Old May 16, 2007 | 11:41 PM
  #50
GoRacer's Avatar
Speed Mach Go Go Go
I have plans for a similar DP but tapered to 3.5". You can get a metalic cat in 3.5" (actually I think they might make one for 4" to) and you don't have A-Spec custom make your mid pipe (with cat & silencer) and exhaust you can get one premade from SMB in 3.5" all the way through.
