my redline suprise
Old Nov 5, 2009 | 05:26 PM
Boost Junky's Avatar
Wing Man
my redline suprise
ok so im not sure if this is suppose to happen, but when i redline my 12a the horn goes off?
happen's every time, no matter what gear or what the situation is. once the needle hits 7 grand i get a loud BEEP!
this normal? like some sort of ghetto redline warning? or is something seriously effed up?
Old Nov 5, 2009 | 05:28 PM
Natey's Avatar
I'm 99% sure that's normal. It's the shift-up buzzer. My FC used to sing to me.
Old Nov 5, 2009 | 05:33 PM
theNeanderthol's Avatar
the torquinator
Yeah its not the horn, its a little buzzer. With some ingenuity, you can adjust when it goes off, disconnect it, or make it into a shift light instead of that annoying buzzer.
Old Nov 5, 2009 | 05:34 PM
DarrenTRS's Avatar
Jolly Green Giant
Its perfectly normal its an "Over Rev Buzzer" that was designed to remind you to shift.
Old Nov 5, 2009 | 05:35 PM
thunkrd's Avatar
i'm a poser
it scares everyone
dammit if its not raining tmw i'm taking my car to los gatos
Old Nov 5, 2009 | 05:37 PM
84gs_rx's Avatar
I love it! haha
"did someone just honk at you?" or "what the heck was that?"
Old Nov 5, 2009 | 06:29 PM
Wing Man
thanks guys glad to know my cars not just trying to eff with my head
shift light you say? and i can adjust when the "buzzer" goes off? i must look into this. i just happen to have a few random shift lights from my old autometer tach laying around
Old Nov 6, 2009 | 01:43 PM
takhay's Avatar
Originally Posted by thunkrd
it scares everyone
What's in Los Gatos? lol
Old Nov 9, 2009 | 07:33 AM
MA2LA's Avatar
My 83 never had one when i had it and then the first time i drove the gsl-se i had i kept hearing it and it took a few times to figure it out,, soon after it was removed.
Old Nov 9, 2009 | 08:16 AM
80's old school's Avatar
common sense prevails....
cats.....
Old Nov 9, 2009 | 09:52 AM
Natey's Avatar
Two big concrete ones.
Old Nov 9, 2009 | 10:28 AM
DivinDriver's Avatar
1st-Class Engine Janitor
It's not an "upshift" buzzer; it's an "Over-Rev Warning." In it's stock form, it marks a theoretical line you cross on a stock engine at your eventual peril.
It came and went a couple times across the 1st gen timespan. 79's had them, 80's did not, later models some did.
Old Nov 9, 2009 | 11:13 AM
the torquinator
here is a little write-up someone did on how to make it adjustable
http://www.jimrothe.com/mazda/overrev.html
Old Nov 9, 2009 | 07:04 PM
takhay's Avatar
That's awesome. The thought of that never occurred to me...
And in LG? Not as many cat anymore. I think the coyotes ate em all...
Old Nov 16, 2009 | 11:23 PM
jinxed4dub's Avatar
So not all cars had them? I thought mine was just broken. I really want one how do I go about getting it. I think the honking noise is awsome.
Old Nov 17, 2009 | 12:40 AM
elwood's Avatar
I have both -- the stock overrev buzzer and a Raptor shift light. I like them both, but I give a slight nod to the shift light because of 2 things:
1) It's more accurate. The OEM tach reads about 10% too high. When the analog buzzer goes off, you're never quite sure what the RPM is. With a good digital shift light, it will go off at exactly the RPM you set it to.
2) It's easier to adjust the RPM limit on the shift light. On mine, I just turn a dial on the underside. With the buzzer, I'd have to open up the cluster . . .
Old Nov 17, 2009 | 10:51 AM
79's had them, 80's didn't... I'm not sure which year they were brought back for, but I know some later FB's had them though the circuitry changed.
On the SA's they were a literal buzzer mounted to the rear of the instrument panel, hooked into the tach circuitry.
Shainiac
Jul 17, 2019 02:20 PM
gxl90rx7
Haltech Forum
6
Jun 30, 2017 11:30 PM
imitek
13
Oct 28, 2015 10:57 AM
