Microtech Area is for discussing Microtech systems
Microtech 1000cc saturated primaries
Old Oct 31, 2008 | 03:42 AM
tony94s4's Avatar
Corn Fed FD
can I use these for primaries with custom rail will they work good with lt10?
http://www.t1raceparts.com/1000cc_sa...r_p/b1000s.htm
I can pick them localy,
few local honda guys r running them and idling like stock around 16afr
will pick up 4 tomorow for my acura gsr turbo so if they do I can get 2 more for the fd
thanx
tony
Old Oct 31, 2008 | 01:17 PM
Aaron Cake's Avatar
Engine, Not Motor
There's nothing that will stop a particular injector from working with the Microtech. It will depend on whether you can turn then down enough and have enough resolution to get them working for your vehicle.
Old Nov 20, 2008 | 01:23 AM
tony94s4's Avatar
Corn Fed FD
just got them,
where should have the staging and what rpm and load
should I kick the secondar 1600s before I retune the car
currently with my stock primaries I have the staging set
95 and secondaries coming on @ 2000rpm @ 05hg
thanx
Old Nov 20, 2008 | 09:11 AM
Aaron Cake's Avatar
Engine, Not Motor
Try around 60% for the staging and see how it works out.
Also, there's a big staging sticky which contains settings for nearly every combination.
Old Nov 20, 2008 | 11:18 PM
tony94s4's Avatar
Corn Fed FD
great I'll try 60,
how about rpm and load,
thanx again
Old Nov 21, 2008 | 09:12 AM
Aaron Cake's Avatar
Engine, Not Motor
RPM and load depends on where your turbo makes boost. 3500 RPM and 2" of vacuum is a good place to start.
Old Nov 26, 2008 | 05:00 PM
rx72c's Avatar
50% will work fine.
Stage it at 1320 rpm
02HG
put 2.43 inyour LOAD 00HG map
and 2.1 in your LOAD 05HG map
And go from their.
Old Nov 28, 2008 | 02:56 AM
tony94s4's Avatar
Corn Fed FD
glad ur back rx72,
hope I will have them plumbed tomorow
so I can dyno tune saturday,
looks like I will be able to instal them without
the top adapters, in case if I decide on 2 more
injectors in the future on my xtreme lower manifold
so they wont be on the way
also we got couple e85 gas stations close to my
work and home so I am doing the switch
rx72c,
with e85 would the above settings work
and what hp will my setup (2x1600&2x1000cc)
max out
thanx again
Old Nov 28, 2008 | 06:08 AM
rx72c's Avatar
2X1000cc and 2X1600cc should atleast get you to the 450hp mark.
With e85 the above settings wont work. Need to be richer.
Start off with those values and slowly add fuel till you get it right.
Old Jan 21, 2009 | 07:34 PM
tony94s4's Avatar
Corn Fed FD
Originally Posted by rx72c
50% will work fine.
02HG
And go from their.
ok got the car running on e85,
we tuned it on a mustang dyno got 460 @ 20psi,
15* timing
with the above 1000cc injectors the car idles @ high 12s AFR 900-1000rpm very smooth,
and cruise is great even @ high 15's afr,
the only problems with above setings we could not clear up the staging we tuned on matrix and we had to raise the staging to 2k rpm and 0" cleand up little but still the hickup is worst then it was with the stock primaries
any sugestions will be great
also I cant figure the idle air controler, r there any tricks to it?
I can change settings but in order to run when engine cold had
to richen up the idle to 10s,
when I start the car the rpms r good around 1300rpm and around 15 second later they drop,
I am hoping I can control the idle in high 12's hot or cold, it Idles even @ 14 when hot but not that smooth,
thanx
Old Jan 22, 2009 | 05:50 AM
BluRR's Avatar
I think you should be cruising in the 14s not 15s. 15s are a bit lean on pump...I dont know if the same applies on E85
Old Jan 22, 2009 | 08:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Cruise as lean as the car will allow without driving EGTs through the roof. The only danger with lean cruising is melting the turbine and flattening seal springs. Running in the 14s during cruise is unnecessarily rich. 15:5 is a great ratio to start with if you run typical timing of about 30 degrees during cruise.
Old Jan 22, 2009 | 11:43 AM
tony94s4's Avatar
Corn Fed FD
dont know wich one did it
with pump gas, stock primaries and ignition I could not get it to cruise clean even on high 14s,
I also put new alternator runing 0 guage wire from batery to alternator and starter and couple 0 guage grounds,
after all these the car totaly transformed feels great
I am running around 35* timing on cruise
Old Jan 22, 2009 | 12:26 PM
tony94s4's Avatar
Corn Fed FD
also the car is full street ported and still idles very smooth at 900-1000rpm
and don't wana confuse anyone with the injectors not sure if 2x1000 & 2x1600cc
r enough for 460whp on mustang dyno
I am also running another set of 1600cc's with additional injector controler
Old Jan 22, 2009 | 06:06 PM
rx72c's Avatar
Youll probably find mate that with all the new grounds etc your whole injection system is working better hence now you can run lean afrs.
Old Jan 24, 2009 | 06:52 PM
BluRR's Avatar
I've been thinking about doing some grounding on my car..only stock ground on it at the moment... where are the recommended points to this?
Old Jan 25, 2009 | 02:32 AM
tony94s4's Avatar
Corn Fed FD
I have the batery in the trunk,
so ran two ground 0guage wires from batery to chasis,
1 from chasisi to starter bolt and one from chasis
to midle iron,
also run one 0guage from batery positive to starter and from
starter to alternator
Old Jan 25, 2009 | 02:33 AM
tony94s4's Avatar
Corn Fed FD
I also have the stock ground to engine and positive to alternator
eplusz
General Rotary Tech Support
15
Oct 7, 2015 04:04 PM
Jmolina0163
Oct 3, 2015 10:04 AM
