Rtek Rtek 2.1 ECU *inside*
Old Feb 8, 2008 | 10:37 PM
Nick_d_TII's Avatar
Here is the inside of the stock ECU with the RTEK 2.1 installed.
You can see the traces on the back of the circuit board, the daughter board on the front and the chip.
I had to see...
Old Feb 9, 2008 | 07:06 AM
rogrx7's Avatar
Turbovert done.
What actually were looking at?
Old Feb 9, 2008 | 12:07 PM
WingsofWar's Avatar
The Firestarter
the chip and daughter board for the rtek 2.x
Old Feb 13, 2008 | 05:49 PM
HAILERS's Avatar
HAILERS
He's showing the location of the *chip*.
Old Feb 21, 2008 | 08:24 PM
NJGreenBudd's Avatar
rx-for-my-7
ZOMG how do I put this thing in there?
Old Feb 21, 2008 | 11:30 PM
rogrx7's Avatar
Turbovert done.
Hey I never got a sticker
Old Feb 22, 2008 | 12:42 PM
The Wankler's Avatar
FKITALL
Nor did I get a sticker...... BUmmer, I wanted to put a new sticker of somesort on my rad cooling panel.
FKITALL
Website will tell ya. A small flathead works great to pull the existing one out.
Old Feb 22, 2008 | 02:05 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
dammit, i want a sticker
Old Mar 4, 2008 | 09:08 PM
rx-for-my-7
Yeah I found a video over there at Digital Tunings website.
Did you guys get the Digital Tuning license plate frame with the actual Rtek??
Old Mar 5, 2008 | 11:02 AM
FKITALL
You fking teasing? :0)
Old Mar 5, 2008 | 07:30 PM
rx-for-my-7
no. i was genuinely curious. I'll find mine, it's around here somewhere.
Old Mar 6, 2008 | 10:21 AM
FKITALL
Ahhhh, that is cool. I was just being sarcastic. I found a real nice Mazda RX-7 one at the wrecker recently.
Old Apr 12, 2008 | 01:58 PM
rx-for-my-7
I found it today:
I think I might black out the website though.
Old May 1, 2008 | 11:36 PM
RX7 JIMMY's Avatar
zoom zoom zoom phssss
once you drove it with the rtek chip did u feel a difference?
Old May 2, 2008 | 01:50 AM
AUGieDogie's Avatar
do you mean BEFORE the 2.1 update or after?
Old May 2, 2008 | 10:01 PM
RX7 JIMMY's Avatar
after
Old May 2, 2008 | 10:48 PM
AUGieDogie's Avatar
I noticed that I can start my car at any time with the 2.1. I love the fuel adjust for my startup. the idle adjust is really conveinent. Haven't messed with the timing or fuel curves because I'm back to stock booste. Definatly worth to$10 upgrade price. Oh and my atmo sensor works again
Old May 3, 2008 | 11:06 AM
RX7 JIMMY's Avatar
i just got this GXL 88' and they swapped it with a turbo im sure its stock ECU cause i see it pushing 5p.s.i . im thinking of getting that chip put in. so where can i find that place where u did it cause i hear its best on those cars.
Old May 4, 2008 | 08:31 AM
rx-for-my-7
I have the Rtek7 Stage 2.1 ECU and my TII only pushes 5 psi, I don't believe the ECU has anything to do with how many psi your turbo makes. If your wastsgate was ported you'll need a boost controller to raise boost levels above that 5 psi mark.
The company is Digital Tuning http://www.pocketlogger.com/index.php?pid=rtek7Digital tuning - Rtek7 ECU. You could have tried searching "Rtek7" on yahoo or google.
The 2.1 is capable of ruining your engine if not used correctly. I think you should do some reading on your car before you try to do anything to the car or you might end up rebuilding sooner than you think.
Old Feb 27, 2010 | 05:45 AM
DC 91 fc3s's Avatar
INNOVATOR NOT IMITATOR
im so poor!!! but i want one!! haha
Old Feb 28, 2010 | 07:13 PM
dennis blackstone's Avatar
Settings
what are your settings for start up and hotstarts.....
Old Mar 1, 2010 | 12:46 PM
Nick_d_TII's Avatar
I just pulled them down a little on the upper temp ranges. It still needs more because I flood a little when its warm, but I just use the flood clear and it fires right up... Maybe someone else has it perfected?
R.O.D
34
Jan 6, 2016 12:09 AM
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
