hose size?
Old Dec 20, 2006 | 02:05 PM
sukimoto's Avatar
rotary head
hose size?
i need to replace the hose in my 1991 gxl that runs from below the oil filter into the firewall, i was wondering what size it was. i havent taken it off yet because i dont want to lose all of the coolant
EDIT: Do i need this hose? or can i cap it off
Old Dec 20, 2006 | 02:43 PM
My5ABaby's Avatar
Rotaries confuse me
I'm assuming you're talking about the coolant line. You need it and it's a shaped hose so just a regular hose won't work because it will kink. Get it from Mazda.
Old Dec 20, 2006 | 03:28 PM
sukimoto's Avatar
rotary head
doesnt it just go to the heater? so if i cap it off i wont get heat?
Old Dec 20, 2006 | 03:50 PM
fc3sna's Avatar
no, you have to bypass it to the other side of the engine. you can use 5/8 inch heater hose, you just have to be careful not to kink it.
Old Dec 20, 2006 | 08:40 PM
RETed's Avatar
Yes, if you cap it, you lose your heater function.
You can't use regular 5/8" hose, cause of all the bends.
You really need to just drop the $30 and get the Mazda OEM hose to replace it.
-Ted
Old Dec 20, 2006 | 09:16 PM
fc3sna's Avatar
i used a normal 5/8ths hose, i just bent the copper fitting on the fire wall towards the driverd side, emergency fix. still works to this day, also if you just plug that one side wouldnt your coolant stop flowing.
Old Dec 20, 2006 | 09:18 PM
Innovation's Avatar
-Ted
Go with what Reted is telling you.
Old Dec 20, 2006 | 09:26 PM
arghx's Avatar
rotorhead
go OEM
it's not worth the risk
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
